HP w1858 - No Power
  • Corbid
    • Mar 2015
    • 13
    • Japan
    HP w1858 - No Power
    I have a HP w1858 monitor that I got used when I was back in the states. It had some occasional power issues where the screen would become totally unresponsive after going into power-saving mode. It would have to disconnected from the PC and reconnected to respond again. While unresponsive the monitor would not turn on at all, no lights, nothing. I didn't have time to mess with it at the time, so it was set aside.
    I recently came upon a little free time and thought I would check the monitor out again. This time, however, it is totally unresponsive from the start. I tried multiple cables, multiple computers and I still get nothing.
    I came across this forum and was hoping the problem would be something simple, but from my limited knowledge, it seems it may be a mess. The caps show no obvious signs of bulging or leaking, the seem to be sitting fairly flush. I did notice some black soot(?) near the main capacitor and transformer on the power board. Encompassed in the soot mess are: positive lead on the main capacitor had some black attached to it, the two blue inrush current limiters(?) appear a little black, the tan resistor was also pretty black (but tested ok), and the side of the transformer also seemed to have some black on the side. A lot of this looked like collateral mess, and I don't see who the main culprit is. Additionally, on the back side of the board there is a section that looks like it might have gotten a bit toasted, along with several hard brown drips on the back, of which I have no clue where they came from.
    So all in all, a mess, but I was hoping an educational one. If by some miracle this can possibly be fixed by replacing a few parts, awesome. If not, hopefully it could serve as an excellent example of a board to trash.
    If any additional photos could be useful let me know.
    Thanks for your advice and time in advance.
    • 31219
    Re: HP w1858 - No Power
    the big yellow transformer needs resoldering for a start.
    • Corbid
      • Mar 2015
      • 13
      • Japan
      Aside from the black soot on the corner, was there something specifically that you saw on the transformer showing it needed to be resoldered? The black seemed to be external to the protective tape and could be rubbed off. This is a learning experience for me, so I'm curious why you specifically pointed out the transformer.
      Without obviously distorted caps or other clearly damaged parts I am at a loss. I'm wondering what the general train of thought is or if there is a mental checklist to go through to check specific components in a case like this. Thanks!
        • 31219
        nothing to do with soot, i was looking at the solder-side foto.
          So what DCV do you on the two legs of the main filter cap int the primary side? Be careful since you are making measurement in the primary side of the circuit, do not touch anything with your hands or body.
          • Corbid
            • Mar 2015
            • 13
            • Japan
            The main filter cap showed about 137V plugged in.
              Just the power supply by itself, try heating up the startup cap C903 right next to the main filter cap with hair dryer to see if you will then get some Voltages at the white connector.
              You also check the DCV right at the two legs of the startup cap to see what you have.
              BTW, you already check the rectifier diode in the secondary side to make sure they are not bad?
              Check the Source resistor R914 also.
              • Corbid
                • Mar 2015
                • 13
                • Japan
                Ran some of the tests you suggested. The startup cap is running at about 14V cold. I didn't notice any difference after heating it up. The resistor tested at 1.4 ohms. Interestingly enough, the D900 diode seems to be shot. Not sure if that's the only problem, but I'm pretty sure I should be getting something through it. Thanks for the help so far. I really appreciate it!
                  How is the D900? Shorted between Anode and Cathode? You should post the pictures and also test it again off the board.
                  • Corbid
                    • Mar 2015
                    • 13
                    • Japan
                    The D900 appears to be open. I get no readings from it running in either direction. Work is busy but I'll try to pull the diode out soon and get some more pictures uploaded. Thanks again, more to come.
                    • Corbid
                      • Mar 2015
                      • 13
                      • Japan
                      Hello again. Sorry for the delay. I take back my last comments on the diode as well. Checked it again and it seems alright. Any other suggestions of what to check? Thanks!
                      • ohren
                        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                        by ohren
                        Hello!
                        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                        Measured voltages with no load:
                        After rectifier diodes
                        12V: 6.17 V
                        5V: 5.67 V
                        Secondary transformer pins AC measurement (really don't know if this says anything)
                        12V: 2-2.5 V
                        5V: 1.04 V
                        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                        03-18-2023, 10:33 AM
                      • mikey5791
                        Is it possible for transformer substitution?
                        by mikey5791
                        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                        My questions are
                        1. How do i test to see if the transformer is in good working condition?
                        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                        Hope you guys understand what i was asking. My intention is...
                        11-03-2022, 02:11 AM
                        High Pressure Sodium Yard light when air conditioner turns light momentarily turns of
                        by sam_sam_sam
                        I have had these 70 watt high pressure sodium yard lights for many years now probably at least 15 years or more and there is a protection diode that after several years starts to go bad and when it does this it has momentarily shutting down the light and then a few minutes later it starts working again
                        This about the forth time I have fixed this one and you can tell if it the diode or not if it lights up and it only shuts down when the air conditioner turns on then it is the diode
                        If it cycling on and off constantly then it is the bulb itself that is the issue
                        06-03-2023, 05:24 PM
                      • titomno2
                        Gaming Laptop Zephyrus S17 TFT not detected every time !
                        by titomno2
                        Hi guys,
                        I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                        So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                        On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                        Then the screen won't work for a long period of time.
                        If I wait 1 or 2 hours it work again most of the time.
                        When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                        01-19-2025, 08:27 AM
                        ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                        This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 04:40 PM
