asus g55v
  • alihomee
    • Dec 2012
    • 1570
    • malaysia
    asus g55v
    need bios file..........urgent
  • alihomee
    • Dec 2012
    • 1570
    • malaysia
    Re: asus g55v
    any one
    • gohar.ashfaq
      • Oct 2015
      • Saudia Arabia
      Re: asus g55v
      neend bios for Asus g55vw plz anyone can help?
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • lrouw84
        Asus vivobook s510ua bios changed to x510un
        by lrouw84
        Hi there,
        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
        01-28-2023, 01:31 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
