HF257 - Help?
  • Apocsol
    • Jan 2015
    • 13
    • United Kingdom
    HF257 - Help?
    Sorry to start a new thread, but I could do with 'do this, then this' sort of advice.
    I've been having what I think/thought was the 2 seconds to black issue with Hannspree's HF257, and was going to follow the guide. I switch the screen on, after a couple of seconds it goes black BUT there seems to be no image even if I shine a light on it. The power light doesn't change colour.
    Shall I just follow the sticky guide? The person who was helping me was very nice but said it likely*wasn't* 2 seconds to black, as no image was visible even if I shined a light on the screen, and to follow other guides on here (which have never ended well, that I can see)so now I'm a bit confused...
    So:
    - Should I just follow the sticky guide?
    - If not, then what do I do?
    master hoarder
    • May 2008
    • 12170
    • Bulgaria
    Re: HF257 - Help?
    Change all of the power supply caps first. I see you only did 3 (the ones with the "Y" vent), or perhaps it came like that? Anyways, the ones with the "Y" vent seem like Chemicon KY or KZE series - those are good. Verify that this is what they are - you should see KY or KZE written on them somewhere.
    The caps that would definitely need replacing are the green caps above them: C242, C243, C244, C263, and another one that I can't see its markings.
    Why replace them even if they look good? Long story short, I have one monitor that would not display an image or display random lines until the caps on the 5V rail on the PSU were replaced.
    While at it (the recapping that is), I see a few more small caps on the video/logic board that probably would be a good idea to replace them. Looks like C70, C61 and the other small cap next to it, C69, and C67. Using this picture as a reference:
    https://www.badcaps.net/forum/attach...6&d=1422926493
    that would be the black caps starting from the bottom of the picture, going up, and towards the left. The caps next to chip next to those headphone jacks are for the amp - those don't need to be replaced.
    • Apocsol
      • Jan 2015
      • 13
      • United Kingdom
      Re: HF257 - Help?
      I love you. Thanks for the detailed rundown - I haven't replaced anything yet, so really appreciate knowing where to start. I'll start there!
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • twonk9098
        Lenovo Legion 5 high fan spin turns off after 34 seconds
        by twonk9098
        I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
        I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
        I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
        I have tried a few new bios but exactly...
        07-14-2024, 11:19 AM
        Copy DMI info easily with Hex editing software and Macro script
        by SMDFlea
        Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
        Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
        02-28-2023, 02:14 PM
      • liquidzorch
        Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
        by liquidzorch
        Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
        10-18-2024, 05:19 PM
      • Rick_1234
        LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
        by Rick_1234
        Good evening, gentlemen.
        I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
        To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
        https://drive.google.com/file/d/1L6S...ew?usp=sharing
        Things I tried
        - Bought a new AC adapter thinking that was the problem but the problem...
        06-22-2024, 04:44 PM
