Dell U2410 Vertical Lines
  • Stanley1843
    by Stanley1843
    06-29-2024, 11:54 AM
  • visionbluedemon
    Help. Sony kd-65x85dj vertical lines
    by visionbluedemon
    First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
    Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
    tried blocking LC lines too, but same results
    is it lcd panel issue or tcon board issue?...
    07-25-2025, 04:56 AM
  • atticus_
    Dell U2518D strobing/flashing with vertical lines
    by atticus_
    I dumpster dived a 1440p Dell U2518D screen the other day and figured I'd take a crack at fixing whatever issues it may have. I powered it up to find that even with no signal input the screen flashes rapidly when turned on and has vertical lines across it. I disassembled the monitor and took pictures of the 3 circuit boards inside it along the way.
    The three circuit boards are labeled "power board l6256-1m", "LED Driver BD L6257-1". and "Interface Board L6127-1". if anyone has schematics for any of them it would be much appreciated...
    06-16-2022, 02:49 PM
  • gpo23
    Sony KDL-40V3000 - Vertical lines
    by gpo23
    i order a t-con because i had bad colors on my SONY KDL-40V3000 :
    With the new t-con the color are good but there are vertical lines on all the screen :
    I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
    Is there a way to fix the vertical lines on the new t-con ?
    Thank you for your help
    gpo23...
    10-04-2023, 09:11 AM
  • Firentiosi
    1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
    by Firentiosi
    Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
    The issues are as follows: the...
    11-27-2024, 12:33 AM
