HP ZR2740w almost dead
  • TeroYyy
    • Oct 2019
    • 6
    • Finland
    #101
    Re: HP ZR2740w almost dead
    Hello all!
    I have this very same monitor on hand, started blacking out erratically at work, got replaced and brought it home. Soon didn't work at all. Blue light for a few seconds, then amber. Didn't get any voltage readings measuring the LED-connector. On the P803 the 5V is live, but 12V pins don't give anything. Thinking of PSU board having an issue with that. Do the LED drivers have their own transformer(s) or are they related to this 12V output? Any suggestions on this? All the caps look fine, but I haven't tested them in any way.
    • Snout
      • Jul 2017
      • 14
      • Sweden
      #102
      One interesting thing I found was that when I plugged my monitor into a UPS outlet (APC SmartUPS 1400), it behaved very erratically. Even though the UPS is line-interactive, and connected to the same outlet as the non-UPS stuff.
      When plugged in non-UPS, it works.. mostly fine. Just a few quirks.
      So there's another curio for people to watch out for.
      • TeroYyy
        • Oct 2019
        • 6
        • Finland
        #103
        I just measured this some more, seems the problem is in the main board as I was able to get the back light on using pull ups to PS-ON and On/Off. So it seems the main isn't giving enough voltage to wake up the power supply board. Are there any suggestions on what might be wrong with it? I'm thinking of caps because the problem began just like a dying power supply problem starts, randomly not starting up and eventually not at all.
        • TeroYyy
          • Oct 2019
          • 6
          • Finland
          #104
          Now I have replaced all the main board electrolytic capacitors, made no difference. Hmmm... What to try next.
          • Snout
            • Jul 2017
            • 14
            • Sweden
            #105
            Follow-up on a different problem - now and then lately the screen had begun to 'freeze up' and then fade to black, like a still image that then dims away. Other threads had suggested overheat under BGA chips on the control board, and since I'm no wiz with BGA-resoldering, I put a large 12cm 12V computer fan over the whole control board. So far it seems to have helped, the thing hasn't blacked out for the month or so it's been constantly turned on lately. Hurrah!
            • remel
              • Nov 2019
              • Romania
              #106
              did you replace the 'big' capacity and the small capacity electrolytic caps?
              I've repaired many PSU and the problems were not with the big caps. Do you have pics or schematics of PSU? if send me pics maybe I can help you
              • TeroYyy
                • Oct 2019
                • 6
                • Finland
                #107
                I replaced only the caps on the main board, not on the PSU board, since I can get it to wake up using the pull up resistor method. I replaced all electrolytic caps on it.
                • TeroYyy
                  • Oct 2019
                  • 6
                  • Finland
                  #108
                  Back at this again, I noticed that the PSU board makes a rattle when I shake it, and it seems to originate from C812, a blue ceramic cap I suppose. It's right next to back light connector, seems to be between the ground potentials of hi/lo voltages. Could this be the culprit? I guess none of these parts should rattle..
                  • Mysza78
                    • Feb 2021
                    • Poland
                    #109
                    Hello gentlemen
                    Does anyone know what type of LED is installed on the backlight bar?
                      by momaka
                      03-15-2023, 10:17 PM
                    • ant3202
                      HP 27es - LED monitor - Monitor Flashing On - Off
                      by ant3202
                      Hi Everyone
                      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                      https://www.badcaps.net/forum/troubl...lashing-on-off
                      The monitor is HP 27es LED Monitor
                      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                      The monitor will randomly blackout and display no signal and will recover again.
                      Sometimes need to power and off again to restore the display but...
                      03-20-2025, 07:30 PM
                    • Rick_1234
                      LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                      by Rick_1234
                      Good evening, gentlemen.
                      I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                      To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                      https://drive.google.com/file/d/1L6S...ew?usp=sharing
                      Things I tried
                      - Bought a new AC adapter thinking that was the problem but the problem...
                      06-22-2024, 04:44 PM
                      Wise Wing F199 19'' LCD monitor - recapped
                      by momaka
                      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                      When I saw the Craigslist post, I wasn't...
                      08-24-2020, 10:58 AM
                    • sew333
                      Pc shutdown, monitor flickered with no signal after 10 seconds
                      by sew333
                      My pc:
                      10850K stock 4800mhz stock Kraken X73 good temps
                      2x16 GB DDR4 GSKILL 3000mhz XMP
                      Seasonic Tx-850 Ultra Titanium
                      Gigabyte Rtx 3090 Gaming OC
                      Aorus Z490 Pro Gaming
                      1 TB SSD
                      4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                      Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                      Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                      Power...
                      02-22-2022, 10:27 AM
