Acer AL1916 pink tint
  • sequille
    • 33
    • United Kingdom
    The "acer" and "no signal" screens don't seem to exhibit this behavior. The moment I plug in the VGA cable the PC image gets displayed with a strong pink tint. The "menu" and "<" ">" keys do noting. "Auto brightens up the screen and does some positioning, but it's still pink, only less so; at the end of the adjustment it goes back to its initial pink hue state. The "power" button also works OK. It's not the lamps, the pink is much more intense, more red and uniform. I suspected the logic board, no bulging capacitors there. Does anyone have any experience with this type of problem?
  • selldoor
    Slow Learner
    • 7870
    Re: Acer AL1916 pink tint
    Try a new vga cable check for bent pins and bad solder on the socket
    • sequille
      • 33
      • United Kingdom
      The cable works OK with another monitor, re-soldered the VGA connector. No change and the "menu" key still does nothing.
      • selldoor
        Slow Learner
        • 7870
        If you cant get to the memory maybe the eeprom is corrupt
        Manual here http://www.manualslib.com/manual/269...?page=1#manual
        Try turning monitor off and unplug then hold the power button in and replug
        Perhaps check the button board and cable
        Does the panel show ehite if you disconnect the lvds cable
        Please can you update profile with country and mains voltage
        • sequille
          • 33
          • United Kingdom
          Updated the country and mains voltage info.
          Checked the buttons board and cable, continuity test OK. Unplugging + replugging while holding power didn't help. The panel is white with the lvds cable removed. I fear it's the eeprom. Do people usually re-flash the eeprom or is it unheard of/rare?
          • selldoor
            Slow Learner
            • 7870
            You may be able to buy one ready programmed ? Pictures might help now
            https://www.badcaps.net/forum/showthread.php?t=39740
            Just spotted this searching for PINK- not your machine but perhaps caps on the main???
            The HP 1907 does have Backlight problems,usually associated with the top set of lamps,due to poor soldering and not good quality wire used on the return wires.Sometimes a failing Lamp can give a Pink screen and needs replacing,BUT if the Black Screen is more Crimson than Pink,then the only time I have seen this,was caused by faulty capacitors on the Logic Board.
            • sequille
              • 33
              • United Kingdom
              Universal LCD controller board from China it is then $7 delivered with all the cables included, jumpers to set resolution.
              • selldoor
                Slow Learner
                • 7870
                That will be interesting - not seen one before. Please update when you try it.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4981
                  • New Zealand
                  It might work, as long as the pinout for the LVDS connector is correct, or you can rewire it if it's not. It sounds like an interesting device. I might have to give one a try myself and see what it's like.
                  If it doesn't work... some other ideas:
                  I have had buttons not working due to shorted debounce capacitor or bad tactile switch.
                  A shorted protection diode to ground or open series component on the Green input line (eg: loss of green signal) could cause a pink image.
                  -David VanHorn
                  • sequille
                    • 33
                    • United Kingdom
                    Just a smd resistor and capacitor on the green input line, both ok.
                    Attached a picture of that universal controller. Don't hold your breath though, delivery time is 15-30 business days
                      I wonder how it will know which pins are power pins for the LCD panel will be for the T-CON on the LCD panel beside the correct LVDS signal lines. You can easily damage this board or the T-con board if the power pin is not correct.
                      The spec sheet of the LCD panel will be required to get the pin out.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4981
                        • New Zealand
                        I don't think it will automatically work like that. That's why I said he will have to verify the pinouts before powering it up. From the pictures I saw online (though it was for a different, but similar board) they have silkscreened the connector names on the board for the LVDS connector so it shouldn't be too hard.
                        -David VanHorn
                          That is why I bring that up, he must be real careful.
                            Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                            This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                            09-06-2024, 09:30 PM
                            09-06-2024, 05:27 AM
                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                            09-07-2024, 05:00 AM
                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 04:10 AM
