I-Inc IF281D Hissing/crackling sound
  • donatdonlo
    • Nov 2012
    • 16
    The Monitor/TV fires up fine and has an excellent picture. After a minute or so there's a hissing/crackling sound coming from the back of the unit near the power switch. Anyone with a quick word of advice what I should look at once I take this thing apart? This year aolne I've repaired over 50 LCD Monitors and a dozen or so motherboards with strong advice and experience featured in your forums.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: I-Inc IF281D Hissing/crackling sound
    Burn marks - fuse loose in holder- switch it on with the back off should give a better idea.
    Wear goggles !
    • donatdonlo
      • Nov 2012
      • 16
      Thanks! I'll respond once I've tried your suggestions.
      • donatdonlo
        • Nov 2012
        • 16
        I removed the back cover and I've had this on now for over 10 minutes with no sign of the previous hissing/crackling sound. The only other thing I did was remove a piece of Nylon tape covered by a piece of Aluminum tape from over the inverter board since that's where the sound appeared to be coming from. The bottom side of the nylon tape has brown spots, some with white marks in the center and cracks in the dried glue on the tape over where the high voltage transformers on the inverter board are located. Is it possible the the transformers were arcing or cooking the dried glue on the bottom of the tape? Is it safe to run this monitor/tv without the tape over the inverter board or is there another option I can install that won't create the same problem?
        • R_J
          • Jun 2012
          • 9558
          There is lots of information on this monitor on this site, search i-inc
          I would check for poor connections in the inverter section around the transformers, and f.e.t's
          also post some good quality pictures of the power/inverter board, (both sides)
          • donatdonlo
            • Nov 2012
            • 16
            It's been running now for 5 and 1/2 hours with none of the sounds it exhibited before and the picture remains perfect. I'm going to try using a piece of Mylar Film over the connectors and transformer, taped down further away from the heat source.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4981
              • New Zealand
              Sounds like the tape\glue may have gone conductive.
              -David VanHorn
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • sir_anthony
                Samsung UE55D6200 Crackling Sound
                by sir_anthony
                Hello, TV has a cracking sound from the speakers, sound from the headphone jack is ok.
                with new speakers the sound is just as bad.
                UE55D6200
                BN44-00457A Power Board
                BN41-01587E Mainboard
                What exactly can I check, what could be the cause?
                How do I repair the error?
                I can't find a circuit diagram on the internet
                thanks greetings from austria
                08-08-2024, 08:16 AM
              • i_am_patch
                Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                by i_am_patch
                Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                04-30-2024, 08:20 PM
              • LEECH666
                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                by LEECH666
                Good day ladies and gentleman!
                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                01-19-2024, 05:46 PM
              • Woxx
                Nintendo switch - clicking/crackling sound when pwr on
                by Woxx
                Hey there, maybe someone can shine some light here.
                I have a Nintendo Switch that doesn't power on. When I press and hold the power button I hear a crackling, fast ticking electric-like sound. Does anyone have a idea of what it could be?
                I have disconnected everything that I can. Done some measurements, reading 17,2 Ohm as lowest on the CPU caps.
                I would highly appreciate your thoughts.
                Br
                Elias
                02-13-2024, 02:01 PM
