Failing HP 2509m Monitor
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    OK its and HP 2509m monitor. It has a flicker on the left side of the screen. Most of what I found online states that its a failing black light tube. The unit has four of them. It is also a common problem with these monitors. Because of my seizure problems I can't have lights blinking in my eyes like this. If I do repair this unit I will be farming the job out. I also might just get another monitor. What would be a good cheap 25 inch monitor from anyone but Hp?
    Mark Twain
    John Paul Jones
    Rod Serling
  • frolovvl
    • Mar 2015
    Re: Failing HP 2509m Monitor
    Hello Court. Have you got your hp2509m fixed? If no I'd like to buy it for parts.
    thx...Vlad
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      thx...Vlad
      Its still working and has stopped blinking.
      Mark Twain
      John Paul Jones
      Rod Serling
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        What did you hit it with to fix it?
          by momaka
          03-15-2023, 10:17 PM
        • ant3202
          HP 27es - LED monitor - Monitor Flashing On - Off
          by ant3202
          Hi Everyone
          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
          https://www.badcaps.net/forum/troubl...lashing-on-off
          The monitor is HP 27es LED Monitor
          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
          The monitor will randomly blackout and display no signal and will recover again.
          Sometimes need to power and off again to restore the display but...
          03-20-2025, 07:30 PM
        • Rick_1234
          by Rick_1234
          Good evening, gentlemen.
          Things I tried
          06-22-2024, 04:44 PM
          Wise Wing F199 19'' LCD monitor - recapped
          by momaka
          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
          When I saw the Craigslist post, I wasn't...
          08-24-2020, 10:58 AM
        • sew333
          Pc shutdown, monitor flickered with no signal after 10 seconds
          by sew333
          My pc:
          10850K stock 4800mhz stock Kraken X73 good temps
          2x16 GB DDR4 GSKILL 3000mhz XMP
          Seasonic Tx-850 Ultra Titanium
          Gigabyte Rtx 3090 Gaming OC
          Aorus Z490 Pro Gaming
          1 TB SSD
          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
          Power...
          02-22-2022, 10:27 AM
