LVDS connectors and cables for LCD's
  • Maxxarcade
    • Jul 2006
    • 973
    Lately I've been doing a lot of work with LCD's, and have needed to get various types of cables, inverters, and control boards depending on what type of panel I'm working with. But I've been a little confused about the cables and connectors.
    When looking at LVDS cables on Ebay or other sources, they are often numbered something like "FIX-30P-S8" or FI-X30-D6".
    I know that the FI-X is a JAE connector series, and I assumed that S8 would mean single channel 8 bit, D6 would be dual channel 6 bit, etc., but that doesn't seem to be the case. Any idea where the numbering scheme comes from?
    Other examples are DF14, DF19, etc., but I'm mainly interested in the 30 pin connectors used on most 19"-42" panels.
  • NolesFan
    Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
    by NolesFan
    Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
    10-24-2024, 06:36 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • CapLeaker
    Crimping CAT7 connectors high failure rates
    by CapLeaker
    I’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
    Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?! ...
    11-09-2024, 04:11 PM
  • Eniaro
    Are USB C connectors standard
    by Eniaro
    I have a number of laptops with damaged USB-C connectors.
    I wonder if I can buy a few replacement connectors from Mouser to keep, as it seems like the wafer in the middle breaks easily and oftentimes causes shorts.
    I do know there are multiple connectors out there, but I'm curious to know which are most commonly used and how can I identify and purchase the correct ones.
    I purchased USB mini-B connectors in the past, only to find out that the connector was flipped (Lenovo smh).
    07-24-2023, 03:07 PM
  • ronaldopdias
    14" MacBook LCDs - has Apple re-introduced a new serialisation type?
    by ronaldopdias
    Since about a month or two ago, we've observed a new type of 'serialisation' on the LCDs and we're just curious whether anyone has seen this
    • New LCDs straight from the factory (not programmed)- if the Mac is restarted or switched on from a cold boot, you must close the lid, then open it again (so two cycles of opening and closing the screen) in order to get display.
    • Transplant the IC onto another screen:
      • If the model and revision match exactly then it will perform as normal
      • If the manufacturer matches exactly BUT its a different revision, the colours are mostly in
    06-28-2025, 09:56 AM
