dell E228WFPc 2 seconds to black
  • wcoffeyiv
    • Oct 2014
    • 11
    • usa
    Hello I have read through the few topics on this monitor (dell E228WFPc) trying to find the “fix”. When it is turned on it will show the 4 color bars and then it is black all in about 2 seconds. I remember reading over the last few years that in many cases the lcd monitors can be fixed so I came to Google and Google lead me to dell and dell lead me here.
    I have no spare ccfl's to test with. I saw a post making a test bulb with a cfl bulb. I have some at home that I need to accidentally “break” so I can make a couple. Most fixes I found include replacing c806, I do not have anything in that spot. While looking for c806 I noticed that c802 feels soft and looks round while the rest are rectangular and solid. I have a pic, it's with the company Iphone so I can't get in to close but I think it shows pretty good what I see. My gut is telling me that is probably what is wrong with the monitor. Is there an easy way to check?
    Re: dell E228WFPc 2 seconds to black
    Check the resistance of the inverter transformer high voltage winding pin 1 and pin 6, use Ohm meter in 2K Ohms range and report the reading. Using at least two test lamps will really help narrowing down the problem.
    • wcoffeyiv
      • Oct 2014
      • 11
      • usa
      if you are talking about the 4 windings at the top of picture "front" then as labeled on the board:
      t801 = nothing (meter stays at 1.)
      t802 = .959
      t805 = .966
      t806 = .964
      • wcoffeyiv
        • Oct 2014
        • 11
        • usa
        if that is bad here is the info from the side of it.
          T801 has open winding which will give you 2-second to black symptom. You may want to verify again by resoldering the solder pads of the just incase there is flux built-up that the meter probe may not be making contact.
          DARFON 80GL20T-23 hard to come by.
          Last edited by budm; 10-24-2014, 02:49 PM. Reason: Correct the transformer to be 801
          • wcoffeyiv
            • Oct 2014
            • 11
            • usa
            801 or 802? 801 has no reading at all, that's what you meant right?
              Sorry, typo, T801 has open winding.
              • wcoffeyiv
                • Oct 2014
                • 11
                • usa
                ok, ill do that this weekend. if i get the same results ill start looking for a replacement. thanks for the help. have a good weekend.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5082
                  • New Zealand
                  Originally posted by wcoffeyiv
                  While looking for c806 I noticed that c802 feels soft and looks round while the rest are rectangular and solid. I have a pic, it’s with the company Iphone so I can’t get in to close but I think it shows pretty good what I see. My gut is telling me that is probably what is wrong with the monitor. Is there an easy way to check?
                  Good observation, but unfortunately that capacitor just looks like it has some glue or such on it. Not a problem unless it turns conductive. But it does not look like the kind of glue which does.
                  In any case, the T801 open transformer is much more likely to be the problem.
                  -David VanHorn
                  • daroo
                    • Oct 2014
                    • 63
                    • ITALY
                    Hi, i've got the same problem in my E228WFPc, everyone suggest to replace c806 but as wcoffeyiv said, there's nothing on that spot.
                    I've checked t801,t802,t805,t806 trasformers and they seem to be ok.
                    Have you got any other suggest?
                    I think i'll try recapping in the meantime
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5082
                      • New Zealand
                      Recapping is an idea, might also help to post photos of your board so we can look at it too.
                      -David VanHorn
                      • HTR-Informatique
                        by HTR-Informatique
                        02-09-2025, 06:51 AM
                      • ChIck3n
                        Dell u2311h 20000 seconds to black issue
                        by ChIck3n
                        So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
                        09-09-2024, 11:44 AM
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • jake-b
                        dell e6540 boots to black screen (no dell logo)
                        by jake-b
                        good morning all,
                        i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                        01-08-2024, 10:29 AM
                      • Swedishpower
                        Dell G3 15 3500 black screen
                        by Swedishpower
                        Hello
                        I have search everywhere for a solution for my problem, but cant find it anywhere.
                        When I was away to trow some garbage i always look in the electronic bin.
                        and this time i find a laptop.
                        Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                        the lamp for charmig is white.
                        Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                        but no Dell logo.
                        I tryed with a hdmi cable to another screen, still black.
                        I started to search solution and tryed...
                        07-06-2025, 06:18 AM
