Dell monitor model se198wfpf problem
  • Vivi
    Banned
    • Sep 2014
    • 101
    this dell monitor se198wfpf got some issues. When I try pressing the menu button (to change color settings etc.) Nothing happens.
    I don't know what the problem is.
  • keepread
    Dell monitor PSU vs Dell laptop PSU
    by keepread
    Hi there!
    Someone gave me their old monitor, it's Dell S2715ht.
    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
    10-30-2025, 04:45 PM
  • angelos
    Dell LED Monitor Model SE2717H
    by angelos
    Hi Guys, i just have a question that is probably easy to answer if you have experience on such matters.
    My Dell Monitors screen was damaged by lightning via the HDMI port. The monitor does come on but cannot display HDMI or VGA image. it says no signal.
    I have ordered the board on Aliexpress. They say 100% working. Don't trust. it.
    My question is, after installing the new board, is there anything else I need to do in order to make this board work. I know on some TV's you need to load software on the board to make it work but this is a monitor or even having to go into service...
    03-25-2024, 04:12 AM
  • SDNarcia
    Dell 15R-5521 keyboard problem (KBC?)
    by SDNarcia
    Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
    As additional information,...
    07-20-2024, 10:47 PM
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
  • Achille15
    Dell N5110 problem
    by Achille15
    so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
    03-29-2025, 04:41 PM
