Samsung SyncMaster 743N
  • Hombre
    • Jul 2013
    • 231
    • Croatia
    Hi
    I have problem with this one.
    When signal is applied the whole screen is red(ish). Without signal applied everything is ok ("Check signal cable" is normal as it should be).
    Replaced all caps altough unnecessary because they were fine.
    Tried it on two different PCs, with different OS just in case it is some driver problem, but no joy.
    I assume it is digital board problem (it has only VGA connector, no DVI).
    Any ideas?
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung SyncMaster 743N
    Tried a second vga cable - check for broken bent pins in vga socket.
    • Hombre
      • Jul 2013
      • 231
      • Croatia
      Ok, tried cable on another monitor, cable is good.
      Resoldered VGA connector from another monitor, still the same red picture with signal on
      • selldoor
        Slow Learner
        • 7870
        Tried adjusting the colour - it mentions you can do this in the manual?
        • Hombre
          • Jul 2013
          • 231
          • Croatia
          Yes, tried that too. If i set red to 0, green to 95 and blue around 35 then colour is about right as it should look. But if I reset it then to factory defaults it's red again, like default setting is Red on 100 .
          OSD is normal, as you can see it on the picture.
          • selldoor
            Slow Learner
            • 7870
            Ok how about cleaning and reseating the lvds cable main to panel - again check pins
            • lti
              • May 2011
              • 2550
              Some of these monitors have a color adjustment feature. The procedure will be in the service manual, but the manuals are so poorly written that I can't understand what they're trying to say.
              This is what the SyncMaster 720N/731N manual says:
              To Analog video, In 16gray or any pattern using black and white and any mode.(16gray and XGA mode recommend)
              1. Push the OSD Menu button to open the OSD
              2. Selectl language English
              3. Push enter button during 5 seconds.
              4. See the screen flashing
              The process will probably be different for the 743N if it even has something like that. I have no idea what "16gray" is.
                • 31065
                foto of the main board near the vga connector would help.
                it may be a bad part buffering the input.
                • Hombre
                  • Jul 2013
                  • 231
                  • Croatia
                  Ok guys, thanks for all your help, and especially to lti
                  Cleaned and reseated lvds cable, but that didn't help.
                  Then tried this metod that lti suggested and it worked! Get in OSD menu, selected english, hold enter button for 5 seconds, screen flashed and that was it
                  Thanks again!
                  PS: on picture it looks like it is still bit red display, but colours are normal
                  • lti
                    • May 2011
                    • 2550
                    I didn't think that would work since those instructions were for a different monitor. That was just an example. The 720N and 731N are completely different.
                    A fault in the input circuit could cause this as well. I was looking at that in a SyncMaster 731N with a slight blue tint, but the schematic is missing the input section. The page marked "Input" is just a duplicate of the page with the voltage regulators on it. I just turned blue down to 31 in the menu.
                      09-07-2024, 05:50 AM
                    • soopacrucial
                      by soopacrucial
                      Hi folks,
                      10-29-2024, 02:40 PM
                    • Ellos
                      Samsung s21 sim recognized but no signal
                      by Ellos
                      I'm just starting out with smartphone repairs and picked up a Samsung S21 to work on. Everything functions perfectly except there's absolutely no cellular signal. The SIM card is recognized, WiFi works fine, but zero network signal.
                      I've tested my SIM in another phone and it works perfectly with good signal, so it's definitely the phone.
                      From what I've read online, this issue is usually caused by the network chip needing to be desoldered and reballed since one of the solder balls might be cracked.
                      I think I've located the SOC that...
                      06-27-2025, 01:31 AM
                      09-06-2024, 11:40 PM
