STAPLES SP9106 -Strange behaviour.
  • infamous7x
    • Jul 2014
    • 6
    • Mexico
    Hello, Recently I bought a second hand Staples 19" display (I think its a AOC rebranded display), anyway, when i got home and hook it up to my computer, 2 things happened.
    1- It either shut off completly, or randomly restart itself.
    2- At some point, my mouse (USB and trackpad) either become laggy, unresponsible or not move at all, but not my joystick (Little blue dot in some laptops) or Laptop's own keyboard , Also my USB keyboard fail, I can even hear the sound Windows plays when you disconnect a hardware.
    So, I pry-opened the external power brick of the LCD and found a blown cap near the output cable, so I replaced it with a brand new one, also I am suspicious about the 400v main cap, because I think I saw some leakeage in one of the connectors, and also, the transformer make a noticeable buzzing sound.
    I hook everything up again and.... same thing!
    So i decided to take apart the LCD, then, I found another 3 blown caps (25v, 220uF) in the power connector board, so I also replaced these, then again I put everything back together, Et voilà, no more shutting off. But! the mouse lagging, keyboard disconnecting thing still happens, until I unplug the VGA cable.
    Same thing happens in another laptop.
    WHY? Could it be a defective power supply?
  • lexwalker
    • Feb 2011
    • 307
    • Malaysia
    Re: STAPLES SP9106 -Strange behaviour.
    Please post pictures of the external brick board as well as the monitor internals. And yes, there is a possibility of power supply problem especially the +5V rail for the USB section which could be derived from the main power rail using a step down linear or switching regulator. That one have to trace at the USB section itself...
    Also do state the brand and series of replacement capacitors used. Most LCD monitor power supplies uses low impedance or low ESR type capacitors, instead of run-of-the-mill standard capacitors. Badcaps and/or wrong capacitors can one of the sources for transformer buzzing issue...
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Have you (or can you borrow) another power supply to test the monitor with?
      They are usually 12volts 4 Amps for this size monitor - what is the rating on yours.
      Lex - I dont think the power is split down to 5v until inside the monitor so perhaps
      a faulty voltage regulator?
      • lexwalker
        • Feb 2011
        • 307
        • Malaysia
        Not referring to the external brick for the +5V regulator, rather on the internal boards (the reason I've mentioned "That one have to trace at the USB section itself"). Possible there could be a badcap around that +5V voltage regulator. Also a bad or failing power supply could create such symptoms mentioned (seems to be insufficient power, note the part "until I unplug the VGA cable")...
        • infamous7x
          • Jul 2014
          • 6
          • Mexico
          I found one picture of the power connector PCB, sorry i dont have a camera right now.
          http://item.taobao.com/item.htm?id=14008538100
          Also I forgot to mention, theres no USB devices hooked to my display, it does have a USB HUB, but its independent from the display.
          Also, all the original caps where CapxOn, and I replaced them with same specs Sc ones.
          I'll try to find a replacement powerbrick today to see if that solves the problem, its a 12v 4.16a power supply.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Ok so are you saying that your PC provides the 5v to the monitor USB hub
            and you are using the hub to split the power from the pc to mouse and keyboard
            If that is the case I suspect there is a problem with the pc supplying power to the hub and videocard?
            Can you plug joystick direct to a separate usb on the pc.
            I know your machine needs 4.16 amps but is that what your brick is rated at?
            • infamous7x
              • Jul 2014
              • 6
              • Mexico
              Nope, I'm not using the Display USB HUB (Also the HUB is completely separate from the display, is encased somewhere else). The only thing pluged to it is the VGA cable and the power supply.
              I've just got my hands on a Sharp 12v brick, but I'll need to swap the connector, lets see how that works.
              • infamous7x
                • Jul 2014
                • 6
                • Mexico
                My display sticker says 12v, 4.16a (MAX), and the brick says 12v 4.16a. Haven't checked my new brick amps yet.
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  Ok think ive got it now you are using it as an external screen on a laptop.
                  which is probably struggling to provide the power to everything.
                  By rights the monitor shouldnt affect the usb but some vga cables do have a 5 volt line so perhaps try a different vga cable check the pins and sockets and look up
                  vga pin out - 5 volt on google
                  • infamous7x
                    • Jul 2014
                    • 6
                    • Mexico
                    Well, everything is working great now ! Replaced the power brick with a 12v 3.6amp SHARP LCD Adapter, now everything is AOK, even played some demanding PC games with no strugle.
                    Thanks everyone for your help
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      Good - but we still dont know what was wrong and problems that fix themselves often tend to come back.
                      • brianh
                        • Mar 2007
                        I have one of these monitors too, and it comes on at first, but after about one minute it starts to flicker, then it shuts off. I do not have the original power supply, but I'm using a PC power supply with more than enough power on its 12V supply. The three CapXon capacitors looked fine, but I replaced them anyway. No improvement. I also re-soldered many joints on the LCD driver board. No improvement.
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          Please can you update your profile with country/mains voltage
                          https://www.badcaps.net/forum/showthread.php?t=39740
                          • Federause
                            HP 250 G7 - Battery Issue (Lid behaviour)
                            by Federause
                            I have an HP 250 G7 for assistance. I've changed the battery (the old was dead) with a not-original.
                            It has a particular behaviour that I've never seen:
                            With the lid open, the voltage is present on the relative pins. Upon a time I close the lid, after 5-10 sec. the voltage drops down to 0. If I re-open the lid, the battery keeps stuck in this situation. I have to connect the power supply to "resurrect" the battery. In this way, I can power on the laptop without any problem and also use it without the power cord. If i shutdown the laptop, keeps it with the...
                            09-08-2024, 03:34 AM
                          • estabilito
                            Acer Nitro AN515-55 weird behaviour on startup
                            by estabilito
                            Hi, I've just repaired acer nitro an515-55 with specs:
                            i7-10750h, rtx2060.
                            Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
                            After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
                            i've tried different bios, different vbios and same behaviour - clean windows install too.
                            Do you have any idea?
                            08-13-2025, 02:52 PM
                          • arashmoayyedizadeh
                            A1990 2019 touchbar weird behaviour
                            by arashmoayyedizadeh
                            Hello to all of you engineers
                            i have a macbook pro a1990 in no power condition
                            another shop had done some works on it with no success (pm ic was reflowed, a little bit of flux around one of the type c rom ic, changing the charging ic)
                            initial state: 5v 0amps on all 4 type c sockets
                            after some inspections i realized the charging ic that another shop installed is isl9239
                            I changed it with right one (isl9240) and the machine turned on and booted into macos
                            weird behaviour:
                            Lcd works ok until it boots to os and as soon as you see login page it goes black...
                            03-26-2025, 12:02 PM
                          • duwane
                            MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                            by duwane
                            Hi All.
                            I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                            Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                            After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                            Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                            10-17-2023, 07:48 PM
                          • Gueric
                            MacBook Pro 820-02020 Weird behaviour
                            by Gueric
                            Hey mon2, it’s me again. My Mac worked fine a full week, then did the same thing again. Charger would not do anything once plugged in, and battery wouldn’t charge. It’s currently drained,
                            And only reacts/shows a charging icon when plugged into the top port (slave CD3217, that I replaced 6 months ago). Plugging it in the master port doesn’t do anything.
                            the trackpad clicks for some reason, even with the charger unplugged.
                            despite hearing the charging chime and leaving it like that for a while it’s still showing this charging icon. I don’t have access...
                            08-04-2025, 09:59 AM
