Viewsonic VB50HRTV
  • 22turbo
    • May 2007
    • 20
    Viewsonic VB50HRTV
    Hello everyone!
    I have a Viewsonic VB50HRTV Television tuner that connects to the RGB port on my computer monitor to make it a tv. Lately it's been kind of finicky and I'm wondering if it might be bad caps.
    I. The Symptoms
    1. When first turned on, it will turn on and then off after about a second. It does this about the first three times I hit the power button, then it will stay on.
    2. Once it is on there is no sound and the volume bar is all garbled. It looks like the bar goes past the normal maximum volume. When I hit the volume down key, and the bar gets back into the normal range, the sound comes back and everything is fine until I turn it off again.
    II. Stuff I've looked at
    1. I let it stay unplugged for a week to see if it would clear the memory, but nothing changed. It even still remembered my channel labels, I think the data must be stored in flash.
    2. I opened up the case and found no less than 34 GSC capacitors in there. None of them appear to be bulging in any way, so maybe they're still ok?
    So I guess the main question is do you think that this could be a cap problem, or something else. Also, if anyone knows where I can find service information, let me know as it would be a great help as I'd really like to fix this problem.
    Thanks!
    Dan
  • Rainbow
    • Aug 2005
    • 1371
    Re: Viewsonic VB50HRTV
    1) Sounds like bad caps. Might be in the tuner itself or in the power supply.
    • 22turbo
      • May 2007
      • 20
      Well I ordered some Panasonic FC capacitors to replace the originals, so hopefully that will fix it! Ill make a post once it's finished to let you all know the result.
      Dan
      • PedroDaGr8
        • Oct 2006
        • 130
        GSC = Goddamn Shitty Capacitors
        or Godawful if you prefer.
        I can't stand to see them in anything.
        • karthur
          Vizio D65x-G4 Volume changes on its own
          by karthur
          On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
          It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
          06-05-2025, 08:13 AM
        • MasterCap
          AVR-2802 no audio, chip questions
          by MasterCap
          I do some hobby repairs mainly of my own junk, and I don't know much programming level repair/mods.
          I got the AVR-2802 over the weekend, sold as working of course, and it worked for 1 night, using EXT. IN 5.1CH jacks, then after power down, the audio never came back. I've reset it, and get nothing on EXT IN or PHONO, despite having everything set right, hooked up right. I can hear lots of relays work tho.
          I just want it for 5.1CH analog inputs , for PC surround sound. I'm not worried about the video or most of the digital stuff for now.
          So far I've traced...
          01-15-2024, 10:52 PM
        • Instafixx
          Macbook A2179 820-01958
          by Instafixx
          Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
          The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
          I checked the Power Sequences below and found this -
          Once a valid external power source (Charger or battery) is connected, the following rails will come online.
          PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
          PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
          05-20-2023, 05:19 AM
        • BigOof
          Marantz SR5007 popping on volume change and mute in Direct Mode
          by BigOof
          I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
          12-12-2024, 06:15 AM
        • DXseekerMO
          Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
          by DXseekerMO
          I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
          As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
          09-15-2021, 05:15 PM
