Hp vs 19
  • hydafl
    • Jul 2009
    • 18
    Hp vs 19
    I have a totally white screen, wife came in to do some work and she fired up her computer and only one screen works correctly. I had repaired the caps around 4 years ago, thing it might be the ribbon cable possibly loose. I took the back off and the cable was secure. I searched the forums here for any knowns but am not able to see anything matching.
    Are there any known quick fix concerns
  • Lumberjack777
    • Dec 2010
    • 464
    Re: Hp vs 19
    Ok, that ribbon cable (LVDS) connects to the panel board. You want to look for a a fuse and check it. Also check the power to the fuse with the monitor on. You may have to remove some tiny screws to gain access to the panel board. If you need to fold it back, be gentle and make sure you don't damage the little ribbons. (TCP)
    A white screen often means a bad fuse on that board. (or no power to the board)
    • hydafl
      • Jul 2009
      • 18
      Re: Hp vs 19
      now its just black. I plugged the chassis in and was working the switch, the backlights would light up and then time out. I may touched something incorrectly now all is black
      • lexwalker
        • Feb 2011
        • 307
        • Malaysia
        Re: Hp vs 19
        What were the capacitors' brand and model/series used for replacements? There are many causes for white screen ranging from noisy power rails (due to badcaps) to faulty Tcon board on the LCD panel (for example, check the fuses on the Tcon board)...
        This one sounds like "2 seconds to black" symptom...
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • flat-earther
          ASUS X54H laptop no backlight
          by flat-earther
          Once upon a time I was casually browsing the World Wide Web with my ASUS X54H laptop which was sitting on my desk, when suddenly the screen turned black!
          After several seconds, the screen turned on again! And so I continued to use my laptop as usual.
          Some time later, the screen went black again! And it hasn't lit up since.
          So here I am on a journey to repair it.
          Not being an expert on how to repair, what I have done is searched the internet for help on a laptop screen not working, and I have checked some things.
          I found out that with a flashlight...
          12-21-2022, 10:40 AM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
