Samsung 245BW power led comes on but no backlight
  • triplefour
    • May 2014
    • 1747
    got a really nice PC monitor here a samsung 245BW that wont turn on.
    well the power LED lights up blue but the backlight does not come on and the screen is just black.
    i took it apart but couldnt find any obviously blown or bulging capacitors.
    is there any useful test i can do with my voltmeter to tell if a capacitor might be faulty? i got a kit to build a ESR meter but i havent assembled it yet...my soldering iron sucks and im waiting for a new one to come in before i try to put it together. and even when thats done, i'd have to remove the cap from the board to test it, correct?
    i did find a resistor that looks questionable...idk it might just be that glue stuff thats all over everything and completely normal but it just looks a little too messy and like something went wrong there. the resistor is right next to (and touching up against) what i think is a capacitor but not the cylindrical kind...its one of those blue ball shaped ones.
    before i start messing around with this power board i'd like to safely discharge the large capacitor. in the past i just used a rubber handled screw driver but i think i read somewhere that its better to discharge them with some kind of resistor so its not so sudden.
    i still hardly know anything about these basic concepts but if a guy says to discharge it with a 1-3 watt resistor, what does that mean in ohms? my volt meter can measure resistors in ohms but i dont understand how to figure out what 3 watts would be...
    as always i will appreciate any and all of your de-noobifying words of wisdom.
    Don't fear the repair...
  • triplefour
    • May 2014
    • 1747
    Re: Samsung 245BW power led comes on but no backlight
    i read in this thread https://www.badcaps.net/forum/showthread.php?t=15647 that the resistors are a common problem so i started checking mine...the one i said looked suspicious checked out fine. so did the 3 that are grouped together (rb805,806,807)
    this one resistor though...RB801 which has the color code brown black yellow gold which should equal 10*10k ohms (would that be 100k ohms?) anyway it only tests at 420 ohms. and a weird thing (or maybe not) is that if i reverse the probes i get infinite resistance. why would reversing the probes have any effect on my resistance measurement?
    • triplefour
      • May 2014
      • 1747
      also is this an accurate test since the resistors are still in circuit? as i said i was able to get correct readings for the other resistors so it seems like testing in circuit is possible...at least in those cases...is there any reason why my in circuit test of this particular resistor might not be accurate?
      • triplefour
        • May 2014
        • 1747
        this is baffling: with the resistor i was just measuring at 420 this is when i have my multimeter in 2000 ohms scale. on 200 ohms scale it reads infinite (makes sense cause its over 200)
        but if i put the scale up to 20k ohms i should expect to see less than 1...somethink like .4kohms, right? but it says 5.85 kohms
        and it i put the scale up to 200k ohms i get 32k ohms
        and if i put it up to 2000k ohms i get 221!
        so which of these readings is correct? why am i getting wildly different numbers just by changing scale?
        • triplefour
          • May 2014
          • 1747
          also im having trouble understanding the resistor color code. for instance i have a resistor here that has 2 shades of green bands....a dark green and a light green. do i just call these both green or does the light/dark mean something too?
          • triplefour
            • May 2014
            • 1747
            and if theres no silver or gold band at one end, then how do you tell which way to read it?
            • triplefour
              • May 2014
              • 1747
              ok so i decided to remove the resistor to get a better reading on it.
              now that i have out out of the board it reads infinate resistance no matter what setting im on.
              the bands are brown black yellow so 10 x 10k should equal 100k ohms...
              is it possible i could have ruined the resistor by too much heat from the soldering iron? whats my best bet at getting a replacement resistor? should i try to scavenge it from parts lying around or would it be a wild goose chase as there are so many different resistors? could i use one rated at any different resistance? like greater or less? or does it have to be exact? im thinking it has to be exact but i thought id ask since with capacitors u can get away with slightly different values...
              • triplefour
                • May 2014
                • 1747
                amazingly in my small collection of salvaged resistors i happen to have a 100k ohms resistor! but it is of a different type that doesnt have the color bands. also it says 2WJ on it...what does that mean? 2 watt joules???
                also it says F054C ...is 54c like 54 degrees celsius? if so that doesnt seem very hot...
                anyway im not entirely sure if i can just go ahead and replace this thing so im gonna wait here until someone actually reads all these posts!
                • bammbammfran
                  • Apr 2014
                  • 476
                  should be 100k
                  so 200k on your tester (when you check the resistor with your tester, do not touch the probes with your bare fingers or it may affect readings)
                  soldering heat should not have affected it
                  part number 100KZCT-ND at digikey.com
                  the pink no lines one should work, just check the resistance before installing it
                  • triplefour
                    • May 2014
                    • 1747
                    i couldnt wait so i went ahead and soldered it in. seems like its ok. but that didnt solve the problem... i notice i only have .88v going to the inverter board..... trying to read some of the other threads on this board but it gets a little too complicated for me. like they say to check the F9222L and they seem to say it has 23 pins and i can only count 20 pins on mine, a lot of which are just stubby pins not connected to anything...
                    please in very simple language explain what i should test next, and how i should test it
                    • triplefour
                      • May 2014
                      • 1747
                      on the F9222L btw i get 58v on most of the pins, but i get 28v on 2 of them
                      • triplefour
                        • May 2014
                        • 1747
                        and for cm802 i get 311v on the side closer to the mainboard and 155v on the side closer to the inverter board
                        • bammbammfran
                          • Apr 2014
                          • 476
                          I could use a good picture of both sides of the board to help.
                          23 pin must have been a typo ?? 20 pin makes more sense but the voltage looks all wrong based on your numbers.
                          Check your tester batteries before going to far.
                          We have to check voltages in several other places
                          Fist spot would be for the 5 volts at the CN801 connector plug that goes to the main logic board.
                          It looks like those pins are marked for values on the board and so are the grounds
                          • triplefour
                            • May 2014
                            • 1747
                            thanks for the tips. ill have to do this tomorrow.
                            • C152Heavy
                              • May 2014
                              • 66
                              • CA
                              Before digging deeper into this board suggest you put the original resistor back in and replace the caps even if they don't look bulged/burst, they're the most common failure point and a cheap and easy replacement.
                              I recently did caps on a 225BW, working fine now and the last thing I re-worked was a Linksys router, caps looked fine but were failed.
                              Good luck & let us know how you make out.
                              C152Heavy
                                Did you already remove all the glues?
                                https://www.badcaps.net/forum/showthread.php?t=34692
                                • triplefour
                                  • May 2014
                                  • 1747
                                  why would i put the original resistor back in when i can clearly test it with the DMM and see that it has infinite resistance! (open) i see your point on changing the caps cause theyre cheap but hey if i can test them first to be sure it would save a lot of soldering and a few bux. my goal is to identify the problem and only change what needs to be changed, not make guesses!
                                  • triplefour
                                    • May 2014
                                    • 1747
                                    i know theres no way my dmm without capacitance reading on it can tell me if a capacitor is good...but is there a way i can at least tell if one is definitely bad?
                                    • triplefour
                                      • May 2014
                                      • 1747
                                      heres the front and back pictures of the motherboard. and yes budm i removed all glues after taking this picture... still no dice. did the flashlight test too...nothing :/
                                      im not getting the 24v out from the power board....
                                      • triplefour
                                        • May 2014
                                        • 1747
                                        i swear my phone should be able to take better pics than that...
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
