Belinea 101711 (111750) Maxdata
  • diodine
    • Dec 2011
    • 46
    • Spain
    Hi all!
    This is one monitor that they have put in my hands for free, it comes from a clerk moving out from an old office and trashing old things.
    First time I switched it on, green light fired on, but a few seconds later it went amber without showing a picture on screen. I tried to look with a torch but I couldn't see anything. Next time I tried, it wasn't even green on, and no more.
    I opened box and looked at the circuits. The scaler seems to be ok but there are problems in the power/inverter/sound board.
    The obvious one: the big cap is toasted. Not a bulge in it but it seems like a dust spill from the bottom. Pushing slightly, the wire gets out. The ohmeter said about 300 ohms.
    Another obvious one. There is a big black burnt shadow on the board around the four diodes near the big cap. The ohmeter said one (the second one, left to right) is shortcircuited.
    You can't see it but the fuse near the mains is measured open, I need to replace it.
    I have searched for the service manual and I think I have been successful.
    There I see big cap is 100 uF 400V, diode is 2a07 and fuse is 2.5A 250V
    I ask for help from you, oh wise people. I can replace those parts, but I want to know what other parts are probably affected and what are in a bad state and can possibly cause the failure again, if you can help me.
    These are some pictures and manual:
  • bammbammfran
    • Apr 2014
    • 476
    Re: Belinea 101711 (111750) Maxdata
    (picture 4)
    the largest main capacitor is toast
    that may be what caused the 4 diodes to overheat and cook the board.
    Usually power issues do not cause amber lights, but this one may have.
    I would start by changing them out
    • Rtech
      • Jul 2010
      • 1095
      You need also to check the mosfet mounted on the heatsink Q801 according to your schematic.Hopefully that will be fine,but better to be certain, before applying power after replacing the failed parts shown.
      • diodine
        • Dec 2011
        • 46
        • Spain
        ¡Successs!
        As you suggested I checked the MOSFET, but it seemed OK.
        I went to the local electronics shop and asked for the parts. As usual, they didn't have the exact ones. So they sold me a 450 V cap, a 3A BIG diode and a box of quick glass fuses. I installed them with some reluctancy, having to enlarge the drills for the diode and so, but to my surprise, the thing started to work as soon as I switched on.
        I leave some pictures of the task.
        Thanks for your help.
        • diodine
          • Dec 2011
          • 46
          • Spain
          If someone needs it, I leave the visual process of opening the monitor case. It is pretty straightforward anyway, but just in case.
          Before starting to unscrew, you need to separate the pedestal, you simply put the screwdriver through a hole in the bottom and press, then slide the base. Then there is a cover that's put in place with little eyebrows and give access to the screws in picture #2.
          When you have unscrewed all, you need to separate the bezel, there are about four eyebrows for each side. Better use a plastic tool for this. The VGA cable have to pass a hole in the back cover, so be careful not to break something.
          The metal back cover is hold in place with eyebrows and simply two screws.
          ¡That's all!
          • Mark D
            Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
            by Mark D
            The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
            10-29-2024, 03:15 PM
          • 2elw
            SVOD4 PCB pictures + parts
            by 2elw
            Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
            STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
            GW1N-UV9UG169C6/I5 FPGA - Its a...
            07-04-2025, 12:23 PM
          • DynaxSC
            Asus Rog Strix B360-I Gaming - Parts Identification
            by DynaxSC
            I have an Asus Rog Strix B360-I Gaming with missing parts. I know there is a resistor missing for sure, but nearby it seems there might have been also a transistor or mosfet. Below the picture of the area on the board with the missing parts. The interesting area is inside the rectangle.
            I'd appeciate if somebody could make a detailled picture of this area from a working board and post it here. Getting the parts values would also be helpful. The revision of the board is 1.02 .
            Thanks in advance...
            08-23-2023, 07:56 AM
          • lorins_core
            BQ24800 to can it be replaced with these parts BQ24780S
            by lorins_core
            Hello to all.
            may I have a question about these Semiconductor parts BQ24800RUYR? can it be replaced with these parts BQ24780SRUYR?
            I need some good advice and also some information about it. thank you and God Bless...
            05-10-2024, 07:56 PM
          • H H
            3090 FE Part Confirm/Identification
            by H H
            I'm hoping someone could help me confirm if I have identified the following parts correctly.
            Apparently the DP cable became stuck inside the graphics card and was yanked out. This caused some sort of short which burned the DP contacts and blew some resistors and ferrite beads.
            The parts needing replacement are on the back of the board behind the HDMI input.
            I have identified the parts as the following:
            C6037: MLCC 0.1uf/16v(0402)x7R W05
            R6016: RES 499 OHM 1/16W (0402) 1%
            LB10911: Ferrite Bead (0402)...
            02-16-2025, 01:09 PM
