Backlight Lamps, Parts, Etc.
  • thetonywarren
    • Feb 2013
    • 149
    What's the best place to get backlight lamps? Ebay? Some other site? Clue me in on where the most cost effective and quality cfl's are. Also any ideas on where you guys get parts. ie, caps transformers etc.
    I currently get caps from digikey, but have looked at mouser and mcm.
    Thoughts?
  • jetadm123
    • 2169
    Re: Backlight Lamps, Parts, Etc.
    ccflwarehouse.com is a good source for lamps. eBay for transformers and obsolete mosfets.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4959
      • New Zealand
      x2
      -David VanHorn
        • 31046
        i'm sure someone told me they charge $$$$ for stuff.
        - yep, just looked.
        fuck-me that place is expensive! a tv could cost less than a set of tubes!!!
        i shop here:
        http://stores.ebay.com/lcd-led-parts
        and where possible, i buy the led conversion kit.
        • thetonywarren
          • Feb 2013
          • 149
          how do you typically retrofit the led conversion kit. where do you connect it to the existing boards?
            • 31046
            you take the ally chanels out with the tubes in, remove the tubes and any crap like rubber spacers,
            then put the strips in with double-sided tape or heatproof glue.
            then if you have a seperate invertor,
            you replace it with the new one.
            it needs 10-30v, a "turn-on" signal, and an optional "dimming" signal.
            all this should be on the original invertor connector.
            if it's a combined psu/invertor then you have to isolate the invertor section and tap the signals.
            i'v done some LG's like this and it's simple.
            first i remove the driver chip so it wont send any fault-codes.
            then i remove the fets,transformers,caps & connectors.
            you dont need to do that - but it creates a space just the right size to slap the new invertor on with double-sided foam tape.
            unfortunatly, the kits only go upto about 24" i think - i'd have to check.
            and they are only for edge-lit.
            so if you have a power hungry bastard with an array of tubes behind it, you have to find another solution.
            a friend of mine does those using reels of led-strip.
            install foto's seem to be here:
            http://www.ebay.com/itm/321297214595
            • triplefour
              by triplefour
              09-13-2023, 10:43 PM
            • DanPoka
              by DanPoka
              02-15-2025, 05:05 AM
            • Comp_Pro
              No Backlight Macbook A1990 820-01041
              by Comp_Pro
              Hello all,
              Am trying to figure out this backlight issue with this A1990 Macbook Pro.
              Tests performed:
              There is no backlight even with a good screen.
              Backlight IC is receiving the correct support voltages.
              Fuse F8400 ok
              Current sense resistor R8400 ok
              Backlight IC is receiving 3.3V on enable pin.
              Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
              Backlight IC receiving 5V from PP5V_G3S
              Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
              I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
              05-06-2024, 10:23 PM
            • cheebster
              iPad Pro 12.9 5th Gen Backlight Issue
              by cheebster
              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
              Anyone...
              05-20-2025, 09:17 AM
            • canadaboy25
              LG Flatron 24EN33TA No Backlight When Cold
              by canadaboy25
              I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
              I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
              03-07-2023, 12:23 AM
