DELL 2007WFPb with 2 seconds to black
  • hkjinlee@gmail.com
    • May 2014
    • 8
    • Korea, Republic of
    Greetings,
    My DELL 2007WFPb stopped working properly from yesterday, which I bought almost 6 years ago. I googled and got here to find lots and lots of priceless information from others. Thank you for those who shared all the experiences.
    Symptom)
    - The screen shows without problem only for 1~2 seconds from being switched on, and goes to black right away.
    - Shining flashlight to the screen reveals it is actually showing the produced image by PC, so the problem may be with the backlight.
    - USB port has no problem
    Brief diagnostic of inverter board)
    - Disassembled it and checked all the capacitors, but they don't have visible leakage or something
    - Checked three transformers: all three show almost the same resistance around 1.04KOhms. (Between pin#1 and #8, #4 and #5 accordingly)
    I suspected one of these transformers would have gone, but they look like being OK. Attached photos of inverter board and PSU. Do you have any idea what I should do next? Thanks in advance.
    • 31090
    Re: DELL 2007WFPb with 2 seconds to black
    6 years old - probably the tubes are worn out.
    cfl tubes have a rated life of 50,000 hours.
    6 years = 52,560 hours.
    not that i trust those numbers - i'v seen tubes go after only a few years.
    • bammbammfran
      • Apr 2014
      • 476
      I agree with STJ on bulbs
      Especially since it looks like they STUFFED 3 next to each other at each side of the screen... TOO MUCH HEAT there even when they only use two !!
      They did this same crap with 3 bulbs on the 21" gateway and a few others
      If you do not have a bulb tester and If you have another working used 19 or 20 inch panel around (17 should also work), you can plug that working screen into 4 of the plugs of the inverter (2 on the one side and two on the other side of the inverter) then use just two of the original screens bulbs at at time also plugged in to help you tell which may be bad.
      might take some plugging and unplugging of different ones at a time to try to figure out which ones are causing issues
      Don't plug the wide 30 pin cable into the rear of the screen .This should make the screen almost white and will allow you to see which lights are actually lighting.
      pink light or darkness on one side of the screen would mean the bulb you just checked is bad.
        • 31090
        fit an led kit!
          • May 2014
          • 8
          Thank you for the advice. I thought I might buy a used inverter kit from taobao(something like eBay of China), but the CCFL looks like the one to blame. I'll give it a try and report the result.
            You can make a couple test lamps:
            https://www.badcaps.net/forum/showthread.php?t=19987
            • HTR-Informatique
              by HTR-Informatique
              02-09-2025, 06:51 AM
            • ChIck3n
              Dell u2311h 20000 seconds to black issue
              by ChIck3n
              So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
              09-09-2024, 11:44 AM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • jake-b
              dell e6540 boots to black screen (no dell logo)
              by jake-b
              good morning all,
              i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
              01-08-2024, 10:29 AM
            • Swedishpower
              Dell G3 15 3500 black screen
              by Swedishpower
              Hello
              I have search everywhere for a solution for my problem, but cant find it anywhere.
              When I was away to trow some garbage i always look in the electronic bin.
              and this time i find a laptop.
              Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
              the lamp for charmig is white.
              Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
              but no Dell logo.
              I tryed with a hdmi cable to another screen, still black.
              I started to search solution and tryed...
              07-06-2025, 06:18 AM
