lg flatron L1710P problem
  • vagos_89
    • Apr 2014
    • 61
    • Greece
    Hello all, i'm new user on site and sorry for my english but i have a problem with my lg flatron L1710P monitor and i would like your opinion if you can help me. While it worked regularly suddenly shut down and did not turn on. I opened it and i replaced the capacitors(4 of them was defective), i also replaced a defective mbr1015ct schottky diode. I closed it and it was working about an hour normally. Ι came out for a walk and When i went to turn on again keep getting a message that says "D SUB POWERS SAVING MODE". If i unplug the vga cable says "no signal" and if i plug the vga says the message above. Can help me anyone? Thank you in advance!
    • 30964
    Re: lg flatron L1710P problem
    vga power saving modes are envoked by removing one or both of the sync signals.
    check the soldering on the connector and follow tracks from pins 13&14
    and try another cable!
    • vagos_89
      • Apr 2014
      • 61
      • Greece
      The soldering on the connector is good. "follow tracks from pins 13&14" i don;t understand
      I'll try and another cable and i'll write again. Thank you!
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        here is schematic if this can help you.
        I think you are in wrong section, there is a computer display section
        did you try DVI connector?
        ...the quieter you become the more you are able to hear...
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
        • Gibon378
          Problem with stopping audio and video for no reason
          by Gibon378
          PC Specs:
          • CPU: Ryzen 5 1600
          • GPU: GTX 1080 Palit JetStream
          • MOBO: ASRock ab350 PRO4
          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
          • PSU: XFX 650W (don't remember what model)
          • OS SSD: ADATA SP920
          • OS: Windows 10 21H2
          Problem description:
          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
          11-19-2022, 09:41 AM
        • perzyk23
          Lenovo T580 - LCD Panel problem - error 0288
          by perzyk23
          Good morning,
          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
          10-25-2024, 12:42 AM
        • SDNarcia
          Dell 15R-5521 keyboard problem (KBC?)
          by SDNarcia
          Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
          As additional information,...
          07-20-2024, 10:47 PM
