Samsung SyncMaster 2333 Display Problem
  • coppercitycomputer
    • Apr 2014
    • 90
    Got a Samsung SyncMaster 2333, in powers up and runs fine, however there is problem with the display. As they say a photo is worth a thousand words. I have not opened it up due the fact it turns on.
    The defect dose not affect the check signal box, it will travel around behind the defect and still be visible .
    • 31091
    Re: Samsung SyncMaster 2333 Display Problem
    that's the panel.
      • Apr 2014
      • 90
      Thanks that what I was worried about, I will part it out, for the boards and scrap the rest!
        • 31091
        keep the tubes and the acrylic sheet - handy stuff that.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4367
          • Italy - Milan
          Damn! It's late now but.. It's not the panel in the screen part but the Tcon that is exchangeable..
          • bammbammfran
            • Apr 2014
            • 476
            This is a 23" so it may not even have a separate tcon ???
            Most tcons didn't show up till the 24s were introduced
              09-07-2024, 05:50 AM
            • howardc64
              Samsung UN55JU650DF network/streaming problem
              by howardc64
              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
              07-09-2025, 12:44 PM
            • Gau_saha
              Troubleshooting samsung syncmaster 2333 BN44-00297A schematic
              by Gau_saha
              Sir,
              Do anybody have IP4L23D CODE BN44-00297A schematic of samsung monitor ? I need the schematic .Please share with me if anybody have it.
              Thanks.
              i
              10-04-2023, 04:47 AM
            • falcontech
              Samsung Syncmaster 943B problem
              by falcontech
              Hello
              I have a problem with a samsung 943B, initially thinking it was a power problem i replaced the power board which is a bn44-00082e, i had a flashing of the ccfl lamps and the monitor would not start, i replaced the power board and the problem is remained, thinking they were the lamps I tested them with a ccfl lamp tester and they are all working, at this point I think it is the main board which is a BN41-01172B, my question is, before making a further purchase there is a way to turn on the lamps without the main board to exclude that the new power board is also broken? Of course without...
              02-16-2022, 12:54 PM
              09-06-2024, 11:40 PM
