So it's time to repair this monitors with broken psus (bad main mosfet, rectifier shottcky diodes..) therefore i was watching for some repair techniques, i've read about the lamp in series and simultaneous use of a variac, since this tool is not on every hobbist house i wanna supply the transformer with what i have, ie 24v maximum (universal latptop psu or 2x12v lead batteries), i wonder if the psu can output a readable voltage, maybe without changing the feedback circuit it will go, under very low or null load, to maximum 4-5v where normally there are 12v and at 100% duty-cycle, but this ensures a right functioning? After to protect circuit i have to insert somewhere 2x 12v lamps in series to protect primary side.. i've read about starting the variac at 70v if i remeber but i don't have a 70v supply source.. thanks, bye.
Lcd monitor test
Re: Lcd monitor test
just use mains running through a halogen spotlamp.
if it's gonna blow, it's gonna blow - the lamp is just to reduce the chances.
a variac is going back to the old crt tv days - it can cause more damage than good on modern psu's because it can simulate a "brownout" condition with the supply looping between powerdown & start till it blows! -
Hi, thanks, i've read about possible problems but not possible damages (to my memory), i don't understand well your last sentence, you want to say that the psu ic is designed to test the ac level so he expect in input at least a 110Vac rectified/filtered? So he needs an input to the Vin (startup voltage pin) as well as Vcc input and 24v are too low and ic shuts down? I have changed 4 main mosfets, them blows and the components spending as reached the monitor value... but i don't like to throw the sponge...Comment
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
by Rick_1234Good evening, gentlemen.
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by sew333My pc:
10850K stock 4800mhz stock Kraken X73 good temps
2x16 GB DDR4 GSKILL 3000mhz XMP
Seasonic Tx-850 Ultra Titanium
Gigabyte Rtx 3090 Gaming OC
Aorus Z490 Pro Gaming
1 TB SSD
4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
Power... - Loading...
