Testing the c5707 transistors
  • ecking767
    • Oct 2009
    • 492
    Re: Testing the c5707 transistors
    Originally posted by playman
    Thank you ecking767 I'll look into that.
    This is a big jungle out there, here are few I found
    http://www.ebay.com/itm/Transistor-T...item19e21c8b66
    http://www.ebay.com/itm/Peak-atlas-D...item3f1f6efb03
    http://www.ebay.com/itm/Transistor-T...item19e734f236
    http://www.ebay.com/itm/Mega328-Tran...item1c3f58273d
    Should I get the MK-168 or the atlas one, they kinda look
    the nicest but are also the expensive ones.[/url]
    minus the Peak-atlas, the other three maybe the same tester but with add features. they all are good tester and I can only speak on what I have on my work bench.
    http://www.ebay.com/itm/251460463679...#ht_3180wt_900
    I dont have this exact model, I have one without the zero force insert socket and the extra smd pads. Its work great on all componets except for CAPs ESR value but good for measuring CAPs value, I have the BLUE ESR Meter for that.
    • playman
      • Jan 2011
      • 252
      Thank you all for your inputs and help.
      ecking767 thanks for that, I'll look into the one you pointed out.
      I guess since the video board is gone I'll just scrap the screen for spare parts since it's only a 17" LCD.
      Thanks again all.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4376
        • Italy - Milan
        A video board for a 17 can cost only 10 euro shipped..
        • playman
          • Jan 2011
          • 252
          Well I checked for a board on eBay there were 3 boards, 2 that costed 266$ and the cheapest one is 38.99$ with shipping
          and in my hands for 123$ after customs and all that.
          So I see no other reason but to scrap it for parts, as it would only sell for about 25-30$
          • DynaxSC
            ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
            by DynaxSC
            I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
            Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
            Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
            The behaviour is also really very strange, i.e.:
            • The disk shows always up in BIOS - so it is recognized, so far so good
            • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
            02-23-2025, 01:33 PM
          • acedogblast
            [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
            by acedogblast
            First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
            Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
            03-01-2023, 08:24 PM
          • hikomalek
            TV LG39LN575S, no backlight power, EAX64905301(2.2), MAP3202
            by hikomalek
            I would be really grateful for your suggestion how to repair a no backlight power on TV LG39LN575S. There is a visible menu on a screen when I use external torch (so logic board and panel works correctly), there is just no backlight.
            I have connected a logic board which is turning on power board and disconnected LED backlight cable.
            Power board:
            REV2.0 2013.03.28
            PCB: EAX64905301(2.2)
            LGIT PCB P/N: 3PCR00184A
            IC LED driver MAP3202
            MAP3202 voltages:
            (1) EN = 2.75V
            (2) VCC = 12.05V
            (3) GATE = 0 V...
            07-25-2024, 10:30 AM
          • Francesc V.
            Onkyo A8200 - Not the right voltages in some transistors
            by Francesc V.
            Hi:
            I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
            With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
            Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
            Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
            I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
            04-19-2025, 07:17 AM
          • Bob Wong
            MSI Crosshair 15 A11UEK. Need help with Transistors!!!
            by Bob Wong
            Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
            In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
            P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
            03-15-2025, 02:02 PM
