Dell 1707 2 seconds to black CCFL testing
  • everell
    • Jan 2009
    • 1514
    I have a dell 1707 with the 2 seconds to black problem. Having already replaced the power supply board, I thought I would test the CCFL tubes next. I was looking on ebay for FFCL testers and found some with different output ratings.
    1300 volts with type 7 mA
    950 volts with type 6 mA
    670 volts with 5 mA
    Does anyone know the rating on those CCFL tubes on the dell 17 inch monitors? Is it the same for the dell 14 inch and 15 inch? So far I have not taken apart the CCFL tubes so for me the "fun" is just beginning.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    Re: Dell 1707 2 seconds to black CCFL testing
    You can build one pair or two pair of test lamps to verify the boards first before spending money on tester.
    https://www.badcaps.net/forum/showthread.php?t=19987
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • DrFalken
      Dell Inspiron 5593 shutdown after 5 seconds
      by DrFalken
      Hello everyone!
      Motherboard model: FDI55 LA-J081P
      Today a customer delivered this laptop completely dead, with the original power supply shorting when plugged into the connector.
      I found and replaced a shorted MOSFET (PQZ3).
      Now the laptop turns on (fan runs fine but no video signal) and after 5 seconds it turns off.
      BIOS has already been updated (both 64MB and 128MB IC)
      +3VALW and +5VALW are still present.
      +VCCIN = 1.8V stable (measured on PLZ1 at power up)
      Abnormal readings:
      PLZ1 to GND = 0 Ohm
      PLZ2 to GND = 0 Ohm
      04-09-2025, 10:45 AM
    • ttmi100x
      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
      by ttmi100x
      Greetings everyone,
      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
      Upon closer inspection...
      07-31-2024, 06:36 PM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • Kambi13
      Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
      by Kambi13
      Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
      Not heat related, everything is ok regarding to that.
      All voltages are present.
      Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
      Motherboard is Cedar 13269-1 F3XMC Rev A00...
      07-12-2024, 06:10 AM
