How to use an universal power supply?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4286
    • Italy - Milan
    Re: How to use an universal power supply?
    i don't know how you search it, if i search 48.L9502.A01 that site finds nothing.
    "I broke part of the pcb" why you had access to the pcb? there was a previous fault?
    • mokie
      • Jan 2014
      • 61
      • spain
      The link that I have put is the powerboard that I have now. It's the same that the Acer AL712 uses, I'm trying to find any service manual to see the pinout but I don't find anything.
      I broke the old powerboard because I was trying to repair a "2 seconds to black problem".
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4286
        • Italy - Milan
        "I was trying to repair a "2 seconds to black problem"" Here i wanted to arrive!...
        If you now try to power up and see the same 2 sec. to black or a flash of the b.light, you can have bad lamps!
        • mokie
          • Jan 2014
          • 61
          • spain
          xD thanks for your help. No problems with the ccfls because I have tested them with an external inverter that I have like this one:
          http://www.ebay.es/itm/390711004363
          • mokie
            • Jan 2014
            • 61
            • spain
            The lamps stays ON if I give tension to the blue wire so I think that this is the ON/OFF wire.
            If I give tension to the yellow wire, the brightness comes down so maybe this wire could be the DIMMER.
            The green wire I don't know what is for.
            I don't know if there's some feedback between the lamps and the display board in order to send the image to the screen.
