Help please!
  • abeeftec
    • Mar 2014
    • 43
    Help please!
    I don't know how this turned into a double post. I wanted to add the model name to the post. I suppose I did something wrong. The first time I tried to post it made me retype the entire post.
    Last edited by abeeftec; 03-21-2014, 06:26 PM. Reason: Accidental double post. Apologies.
  • alltvrepairs
    Hisense 55AS6G screen double sided tape required
    by alltvrepairs
    I need to replace the LEDs of this TV. The screen is glued with double sided tape. This video shows the proceudre required.
    I need a source for this type of double sided tape adhesive please.
    https://www.youtube.com/watch?v=bN6g...nel=QUADRA-NET
    Tks!
    07-17-2025, 09:32 AM
  • howardc64
    TCL 49S405 double image
    by howardc64
    LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
    This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
    06-23-2025, 03:20 PM
  • Cornito
    Samsung UE55RU8000 reboot and then double image after heating up
    by Cornito
    Hello team,
    I'm back with another tv and another problem.
    I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
    First, reboot issue, I use tape Method to find out the right side that cases the issue.
    Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
    Then double image reduce in height and move to the top.
    The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
    When I...
    03-31-2024, 01:37 PM
  • repair-it
    Need help identifying this (double?) diode
    by repair-it
    I tried to locate online without any success but maybe someone else might have better luck. If it is a double diode - it's done - based on the reading I got in diode mode....
    07-14-2025, 10:25 AM
  • tbsmith
    Ninja DCT401 Double oven/air fryer Possible microprocessor issue?
    by tbsmith
    I'm having a random issue with this otherwise nice double oven/air fryer. It sometimes does not respond to the controls. Sometimes only the upper control buttons work, sometimes they all work and sometimes none of them work. The power supply is good as the control board has a steady 5V and 3.3V. The pushbutton switches are all good as tested with multimeter. When the buttons are working, there is about 2.5V to the high side of the pushbutton. I'm assuming pressing a button grounds the input pin to the microprocessor. When the buttons are not working, there is about 0.3 volts on the high side....
    07-12-2025, 11:40 AM
