AOC 27G2O5 bad screen
  • giulio93
    • Aug 2021
    • 289
    • Italy
    Hi everyone, i have this monitor that has this problem. The monitor goes on and the buttons work. Click image for larger version
    Anyone know what Is the problem? Thanks
  • lotas
    • Jan 2016
    • 4904
    • Russia
    It looks like the monitor was exposed to rain...
    • giulio93
      • Aug 2021
      • 289
      • Italy
      It Is fixable? What Is damage?
      • giulio93
        • Aug 2021
        • 289
        • Italy
        I open It and noticed the water. I dry off every layer. Now I have 2 questions. The sheets inside have a correct orientation? I'm worryd i reverse some of them.
        In secundis I found some brocken led. Where can i find a replacement?
        • lotas
          • Jan 2016
          • 4904
          • Russia
          Better look for a donor with a broken screen and rearrange your matrix.
          • giulio93
            • Aug 2021
            • 289
            • Italy
            I don't have a doner. I noticed that the leds don't work are all nearby. And there Is 2 components at the estremità (meaby 2 diods). Can be them the problem?
            • giulio93
              • Aug 2021
              • 289
              • Italy
              Here the led situation
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                Possibly one of them is bad, and the whole segment will then stop working.
                • giulio93
                  • Aug 2021
                  • 289
                  • Italy
                  But i don't see a separation in the led strips 😭. I have a test Power supply, i can apply Power on each One by One to see the One that Is faulty?
                  At witch voltage the led works?
                  You meaby miss another question. The sheets inside the monitor have an orientation?
                  • lotas
                    • Jan 2016
                    • 4904
                    • Russia
                    Yes! It is important.
                    • giulio93
                      • Aug 2021
                      • 289
                      • Italy
                      Is there a metod to determinate the correct orientation of them?
                      For the leds testing? Can I test them One by One with a Power supply?
                      Thanks you so much
                      • lotas
                        • Jan 2016
                        • 4904
                        • Russia
                        These sheets should have the correct sequence, the first one is thick (plexiglass) and should be positioned correctly up and down, do they have any protrusions or slits on them? Then thin ones (1 or 2 sheets), if there are two thin ones, then you also need to lay them out correctly (which is the first, which is the second... Here it was necessary to remember the sequence.
                        • giulio93
                          • Aug 2021
                          • 289
                          • Italy
                          The sequence is correct. Meaby i reverse upside down One or 2. Can be a problem?
                          Can I test the led singularry?
                          What Is the tension of the led?
                          • giulio93
                            • Aug 2021
                            • 289
                            • Italy
                            Click image for larger version  Name:	IMG_20240630_192453.jpg Views:	0 Size:	658.0 KB ID:	3299785
                            I test each led individually and each works fine. Now I don't understand.. can the problem be the two components at the extremity of the section that doesn't not work?
                            What Is that?
                            • giulio93
                              • Aug 2021
                              • 289
                              • Italy
                              No one knows?
                              • mmccomputer
                                problem with replacing lcd screen
                                by mmccomputer
                                I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                                otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                                If anyone has any information on the subject...
                                12-15-2024, 03:44 PM
                              • wattage
                                AOC AG493UCX 49-inch monitor - Firmware request
                                by wattage
                                Hello Badcaps Community,
                                The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                07-13-2025, 04:41 PM
                              • abajor
                                A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                                by abajor
                                Having this very weird issue.
                                The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                                I swapped with a working screen from an A2141 waiting for parts.
                                The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                                The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                                04-27-2024, 01:37 PM
                              • Chrissygizmo
                                Sony KD-55XG9505 lines on screen problem
                                by Chrissygizmo
                                Hello again everyone,
                                This is my latest mission, to try getting this Sony tv back to normal working order…
                                I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                02-19-2025, 11:31 AM
                              • keepread
                                Dell monitor PSU vs Dell laptop PSU
                                by keepread
                                Hi there!
                                Someone gave me their old monitor, it's Dell S2715ht.
                                The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                10-30-2025, 04:45 PM
