Acer P193W
  • ViperRunner
    • May 2013
    • 32
    • Portugal
    Acer P193W
    I bought this 19" monitor for cheap some time ago, and i'm trying to fix it.
    Already bought a new ps board for it, and it gives me acer logo but doesn't detect any vga connection.. someone knows if it's fixable or if it need a new graphic board?
    I'm also leaving here the service manual for this set, for anyone who needs it.
    Thanks for looking!
    Best regards
  • Phoenix83
    • Jan 2014
    • 53
    • Slovakia
    Re: Acer P193W
    Firstly, try it with another computer.
    • ViperRunner
      • May 2013
      • 32
      • Portugal
      Re: Acer P193W
      Already tried with 3 different computers, and i use all of them everyday with other monitors and projectors, so it's not a computer problem unfortunately
        Re: Acer P193W
        Both DVI and VGA ports do not detect the video signals?
        You cab check all the signal pins on the VGA and DMI to see if the protection diodes are shorted out.
        For example the VGA pin 1, 2, 3, 9, 12, 13, 14 ,15.
        • ViperRunner
          • May 2013
          • 32
          • Portugal
          Re: Acer P193W
          Hi Bud,
          Thanks for the quick reply!
          Mine is the VGA only version. Ok, as soon as i arrive home i'll test them! in around an hour i should already say something!
          regards
          • ViperRunner
            • May 2013
            • 32
            • Portugal
            Re: Acer P193W
            Already tried and of the pins you told me to check, the pin1 is the only One that males contact with pins 4,6,7,8 and 11.
            Thanks!
            Regards
              Re: Acer P193W
              What resistance do you get?
              • ViperRunner
                • May 2013
                • 32
                • Portugal
                Re: Acer P193W
                The following:
                1 to 1 = 1,1
                1 to 2 = 135
                1 to 3 = 135,9
                1 to 4 = 62,2
                1 to 5 = 5,01
                1 to 6 = 62,2
                1 to 7 = 62,2
                1 to 8 = 62,2
                1 to 9 = 102
                1 to 10 = OL
                1 to 11 = 62,2
                1 to 12 = 33
                1 to 13 = 0,714
                1 to 14 = 1,007
                1 to 15 = 32,83
                  Re: Acer P193W
                  That is not the correct testing, you want to test the Ground pin (pin 4, pin 11 ) against these signal pins:
                  4 to 1 =
                  4 to 2 =
                  4 to 3 =
                  4 to 13 =
                  4 to 14 =
                  and (in case pin 4 and pin 11 are not tied together inside the monitor)
                  11 to 1 =
                  11 to 2 =
                  11 to 3 =
                  11 to 13 =
                  11 to 14 =
                  Make sure to report the reading how it shows on your meter so we will know the correct resistance. I.E. Ohms, K Ohm, M Ohms.
                  We are basically looking to see if the signal pins are shorted to ground due to shorted out protection Diodes or not.
                  • ViperRunner
                    • May 2013
                    • 32
                    • Portugal
                    Re: Acer P193W
                    Sorry, i've just now noticed that it doesnt appear the ACER logo, i confused with some videos i've seen talking about issues.. what happens with mine is what i recorded on the following youtube video. I've just recorded it right now:
                    http://www.youtube.com/watch?v=Aa_HsmpdM28
                    thanks and once again sorry for misleading!
                    is this issue easier or harder to resolve?
                      Re: Acer P193W
                      OK, that is a strange symptom that I have never seen before.
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        Re: Acer P193W
                        Does it do the same when connected to a pc producing an image
                        Sorry just re read the 1st post
                        • ViperRunner
                          • May 2013
                          • 32
                          • Portugal
                          Re: Acer P193W
                          On the video it is already connected to a computer that is producing image.
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            Re: Acer P193W
                            Can we get a good clear picture of the main board.
                            Please do the ohms test as Budm asked in earlier post.
                            Any chance that the main board could have been changed by anyone
                            and is not the original/correct one? what is the part no on it
                            Another thought - check the vga socket has continuity on each pin (hole)
                            • ViperRunner
                              • May 2013
                              • 32
                              • Portugal
                              Re: Acer P193W
                              One update, decided to take the bullet and also replaced the main board for a new one.
                              And it keeps the same symptoms :/
                              https://www.youtube.com/watch?v=Aa_HsmpdM28
                              Now i am really upset and disappointed
                              And one other thing, the first service manual i posted was wrong, this is the right one for the ACER P193W that i have, for the case someone needs it too.
                              • ViperRunner
                                • May 2013
                                • 32
                                • Portugal
                                Re: Acer P193W
                                Sorry for the late reply selldoor, but was waiting on the boards to arrive and replace them to answer you better and don't make you waste any time if that resolved!
                                The PSU board is a ilpi-031 and the mainboard is a ilif-046. Now they are both new, and didn't resolved the problem
                                  09-06-2024, 05:27 AM
                                  Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                  This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                  09-07-2024, 05:00 AM
                                  Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                  This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                  Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                  This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-07-2024, 04:10 AM
                                  Acer Aspire A317-53-52WQ + Pack Gold Acer 17'' Notebook 3 Specification for Upgrade or Repair
                                  This specification for the Acer Aspire A317-53-52WQ + Pack Gold Acer 17'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-52WQ + Pack Gold Acer 17'' boardview and A317-53-52WQ + Pack Gold Acer 17'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                  09-07-2024, 03:10 AM
