[Help] Dell 2405FPW whitescreen
  • allenpan
    • Feb 2014
    my Dell 2405FPW only display whitescreen, and i check the and replaced all the 470uf 35V caps (6), but now still the same whitescreen, what should i look or prob for?
    Re: [Help] Dell 2405FPW whitescreen
    Check the fuse on the T-CON board to see if it has either 5VDC or 12VDC at BOTH ends of the fuse with ref. to the chassis ground.
    • ulyanoff
      • Jun 2016
      • 12
      • Ukraine
      Hi , Some panels have a test mode, for this you need to submit 5V to T-con with disconnected cable LVDS. (in offline mode). Good Luck!
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
        Dell Thunderbolt Firmware
        by SMDFlea
        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
        The SKU is in brackets (****)
        EDIT: NVM65...
        01-26-2025, 06:22 AM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
