Acer AL1916W, can't find the problem
  • Phoenix83
    • Jan 2014
    • 53
    • Slovakia
    Hi everybody.
    Have in my hands monitor AL1916W, but is broken. Both leds (green and amber) lighting at the same time and that's all. I changed the Electrolytic capacitors on the power board. Seems it works, because on the connector to the logic board I measured all the tensions, but slightly different. On the PCB is written +13,8V I measured 14,08 and is written +5V measured 4,97V. I don't know if it can be the problem, don't think so. On the logical board measured 3,29V on both Voltage regulators ABF646 (U6, U7) marked with red circle on the pic. I do not know whether to be both 3.3 V, or one of them is wrong. I have the service manual but for a different model and there is one 3,3V and the other one 1,8V...
    Also the inverter transformer is too noisy. I need to build a tester to check it out.
    I'm sorry for my english
  • selldoor
    Slow Learner
    • 7870
    Re: Acer AL1916W, can't find the problem
    Probably ok but did you check the little white fuse on the main board near the connector to the power board. - Can you post picture of the bottom of the power board.
    • selldoor
      Slow Learner
      • 7870
      There is another small fuse F200? on the back of the power supply?
      And another one maybe F300? one has an S (2amps) on it the other a W (4amps)
      • Phoenix83
        • Jan 2014
        • 53
        • Slovakia
        Fuse on the logical board is ok, also fuse 200 on the back of power PCB.
        Here's photo of the power PCB back
        • selldoor
          Slow Learner
          • 7870
          And Another - see late edit
          So 3 fuses 0ne green one one with and S and one with a W
          • Phoenix83
            • Jan 2014
            • 53
            • Slovakia
            I found them. Are fine.
            • selldoor
              Slow Learner
              • 7870
              Drat - I love a blown fuse
              Also that green fuse is a new type replacement for a fuse with a W, so someone has changed it?
              How about testing the secondary windings on the inverter transformer.
              Does the backlight ever flash?
              Looks like someone has been soldering there as well?? Cant tell for the glue but the middle connectors dont look great.
              Power off - meter on ohms 2000 test S1 to S2 and S3 to S4 as in pic
              • Phoenix83
                • Jan 2014
                • 53
                • Slovakia
                I think someone has played with this monitor. Friend gave me it, cuz is broken. I only changed the capacitors. The backlight do nothing. Only thing the monitor do is both leds lighting up.
                S1 to S2 = 745 ohm
                S3 to S4 = 747 ohm
                • Phoenix83
                  • Jan 2014
                  • 53
                  • Slovakia
                  Shouldn't there be some capacitor? Like above? See pic.
                  • selldoor
                    Slow Learner
                    • 7870
                    Well the transformer seems good - when there is a lull in suggestions I would remove the glue and old solder and resolder it.
                    Also now we know it has been "played with" check any of the joints that have been resoldered AND the components in case old faulty ones have been put in or caps replaced the wrong way round. Caps that have been replaced also make a list of board numbers C*** and the uf and v values on them and we will try and check they are in the correct positions. - perhaps a tomorrow job ?
                    • selldoor
                      Slow Learner
                      • 7870
                      Doesnt look like there has ever been one there.
                      I would say test the ccfl bulbs on something but as you have no voltages at all
                      doesnt seem much point yet.
                      • Phoenix83
                        • Jan 2014
                        • 53
                        • Slovakia
                        I'll leave it for tomorrow. I'm already tired.
                        • Rtech
                          • Jul 2010
                          • 1095
                          Check the mosfets next to the inverter transformer,,they do fail on a regular basis.
                          • Phoenix83
                            • Jan 2014
                            • 53
                            • Slovakia
                            Hi
                            Here's the list of changed caps
                            CE101 - 220uF/35 V
                            CE102 - 1000uF/16 V
                            CE103 - 1000uF/35 V
                            CE104 - 1000uF/35 V
                            CE105 - 2200uF/16 V
                            CE107 - 47uF/63 V
                            CE108 - 22uF/50 V
                            C204 - 220uF-35 V
                            Tested the mosfets Q205 and 206, seems been OK.
                            I tested them as follows (out of circuit):
                            Multimeter on diode test.
                            1st connect negative lead to the Mostet's source.
                            2nd connect positive lead to the gate.
                            3rd moved the positive lead to the drain. DMM should show a short circuit.
                            4th with the DMM still connected (-to S, and + to D), connect together Source and gate with some wire. DMM should show a open circuit. Then the mosfet should be good.
                            I do not know of another method, this one I remember from the school.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4289
                              • Italy - Milan
                              R105 smd near output connector must be tested, anyway if is ok your problem seems to be on main/scaler board. I'm not able to find datasheet for ABF646 so you must post all 3 pins voltages.
                              anyway them has no resistors near so must be fixed output..
                              • Phoenix83
                                • Jan 2014
                                • 53
                                • Slovakia
                                R105 = 0,5 ohm
                                I'm unable to find it too. But I think is something like LM117MPX-3.3.
                                Here's voltages on that regulators. (pic)
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4289
                                  • Italy - Milan
                                  Regulators are surely good, at this point i don't know which steps you can do, if you have an oscilloscope you can test if the quarz osc. is working, if you don't you can try and replace it, but changing blind-like is not funny, last chance is to search for a replacement main/scaler bd or a replacement RTD2120S that i don't have searched but i guess is a mcu, you need one programmed for this monitor model.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    Hi
                                    CE101 - 220uF/35 V
                                    CE102 - 1000uF/16 V
                                    CE103 - 1000uF/35 V
                                    CE104 - 1000uF/35 V
                                    CE105 - 2200uF/16 V
                                    CE107 - 47uF/63 V
                                    CE108 - 22uF/50 V
                                    C204 - 220uF-35 V
                                    All I can find so far is that they all appear to be in the right way round
                                    and that CE107 is meant to be 47uf - will continue tomorrow.
                                    Looking at the back of the board some of the soldering is really bad - I was going to try and find a picture of someone elses board but have not had time.
                                    Please check carefully and resolder as required the red one doesnt look to have any solder on at all!! That may be right but cant tell what is on the other side?
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4289
                                      • Italy - Milan
                                      I don't think that those solder joints are bad, it's only a fact of reflections, after those compo. soldered have no influence in monitor functioning, are for filtering noise that psu produces versus mains (electrical net)...
                                      • Phoenix83
                                        • Jan 2014
                                        • 53
                                        • Slovakia
                                        The solderings are fine, like Davi.p wrote, is only reflections. I do not have an oscilloscope. I'm biding one USB osc. on Ebay.
                                          09-06-2024, 05:27 AM
                                        • fmajbour
                                          Acer Nitro 5 model A515-51 keyboard problem
                                          by fmajbour
                                          I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                                          Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                                          i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                                          I have check the keyboard connector on the mainboard every thing looks ok.
                                          Then i replaced the keyboard with new one ......same problem exact same keys problem.
                                          I need your advice if anyone face...
                                          11-13-2023, 09:50 PM
                                        • ahmarzo
                                          Acer TMX314-51 laptop battery problem
                                          by ahmarzo
                                          I have acer laptop tmx314-51 with part no 6050A3020501.
                                          The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                                          But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                                          I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                                          The schematic is not available...
                                          04-11-2025, 09:14 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
