Dell 2007FPB Component ID Help please!
  • totalgearhead
    • Jan 2023
    • 8
    Hi All, I need help identifying a replacement for D1 (same as D2 through D5) on the Dell 2007FPB board please? The board ID is an LG Philips LM201W01-SLC1-F11. Thank you for any help! It popped under power while troubleshooting, oops!
  • totalgearhead
    • Jan 2023
    • 8
    I forgot the most important photo.
    • lotas
      • Jan 2016
      • 4786
      • Russia
      DALC208SC6
      This is a protective diode assembly, try without it, the main thing is to check if the track is damaged.
      • totalgearhead
        • Jan 2023
        • 8
        Thank you lotas! I have fixed the trace to continue the troubleshooting. I have flashing power LED, 1 and 4 on the bezel with no output. Appreciate your help on finding that component. How did you identify from the markings what it was? Or is that just experience? thanks again!
        • totalgearhead
          • Jan 2023
          • 8
          following this thread and testing components, I have 45-56 volts AC where i should have DC volts? Not sure what happened? I removed to test this component and I'm not sure if it's supposed to ground to the heatsink? https://www.badcaps.net/forum/troubl...blinking/page2
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • ckom26
            Dell 2007FPB compatible boards
            by ckom26
            Hello, folks.
            Please, forgive this dumb question but I own a 2007FPb whose logic board is FUBAR (really). Obtaining a replacement is not easy any more (or unreasonably expensive) so I was wondering if replacing the logic board with one from the same line (e.g. 1708FP or 1907FP) would bring it back to life. Are the resolution capabilities for each one "hardcoded" into the main GENESIS chip or auto-sensed and applied? Has anyone tried something similar?
            07-04-2025, 07:02 AM
          • master3112
            by master3112
            07-29-2025, 01:55 PM
            Dell Thunderbolt Firmware
            by SMDFlea
            Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
            Some models have a choice of 2 different firmwares, it depends on the dell SKU.
            The SKU is in brackets (****)
            EDIT: NVM65...
            01-26-2025, 06:22 AM
