Re: What bad glue can do to the board
Do you think Tetrachloroethylene-based silicone will work as well as the artificially high-priced "electronics" branded stuff?
I use electronics grade Silicone RTV, regular Silicone RTV is corrosive due to acid content.
http://www.amazon.com/Clear-Electron.../dp/B0063U2RT8
http://www.hmcelectronics.com/produc...licones/RTV162Leave a comment:
Does anyone know what kind of insulation adhesive Antec uses in their Delta-built PSUs, specifically the Earthwatt D's? It's like a very dense closed cell foam. Also, what do you use for adhesive? Is RTV silicone safe to use?Leave a comment:
I have dealt with this glue problem since the 70's. They get old, turns dark brown then becomes conductive and corrosive.Attached FilesLeave a comment:
I'm a bit confused? They are smart enough not to put glue that conducts electricity.
What happened to this glue? What caused it to make such a mess?
Temperature, chemical reactions or something else?Leave a comment:
wow! thats glue? it looks like chocolate salt water taffy!Leave a comment:
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
