samsung LA 22A450C1
+ More Options
Posts
  • aanan
    • 222
    • India
    samsung LA 22A450C1
    samsung LA 22A450C1 [BN64-00803A ] no diplay smps on 13.5v present.red led glowing i dont no inverter circuit i need schematic.
  • aanan
    • 222
    • India
    Re: samsung LA 22A450C1
    anyone please.
    • aanan
      • 222
      • India
      i upload board image.
      • Rtech
        • Jul 2010
        • 1095
        Check Inverter transformer secondary windings for resistance.
        • selldoor
          Slow Learner
          • 7870
          see here for pin out - no power to board - meter on ohms 2000
          test s1 to s2 an s3 to s4 and post results.
          http://lcdparts.net/TransformerDetai...ProductID=3721
          Also test that green torpedo fuse F301
          • aanan
            • 222
            • India
            Friend Rtech & selldoor.
            i check fuse it is ok.
            TR pinout s1 to s2 1.023 ohms s3 to s4 1.023 ohms
            i suspect inv osc ic i need ic pin voltage.
            Thanks for reply.
            • Rtech
              • Jul 2010
              • 1095
              That is the Green fuse you have checked ?????,also have you checked the Backlights ??
              • aanan
                • 222
                • India
                i checked fuse & backlights.no output hi voltages inv transformer.
                Thanks Rtech.
                • aanan
                  • 222
                  • India
                  Thanks Rtech.
                  Please schematic upload.
                    Can you read the P/N of the SMD PWM IC and the MOSFETs which drive the inverter transformer?
                    Also check the DC voltage on that connector where the wires go to the logic board, I can see the labeling but cannot read them. We need to find out if the inverter circuit is getting the inverter_on (BL_ON) signal or not.
                    • viziks
                      • Mar 2012
                      • 33
                      • India
                      Thanks for reply.
                      This does not seem to be an Inverter issue at all.
                      This is a TV and not a standalone Computer monitor,when you power on the power led should blink and come on.Connect AV signals and after power on keep pressing source(Input select) on remote,if TV is working with signals connected you should be able to hear the Audio.
                      I suspect the Logic board is defective which is a known failure for this model.Check 3V3,5V and 1.5V on the logic board and if all voltages are present suspect defective main board.
                      On this model I was not able to bring on the Back-lights by pulling up the pin from 5v on logic board.
                      I have recently repaired this TV motherboard with the same problem of No operation except power led blinking when operating with remote or panel switches.
                      Just heated the metal shielded box which has the micro processor ICs.
                      Samir
                        "On this model I was not able to bring on the Back-lights by pulling up the pin from 5v on logic board." if you do not disconnect the BL_ON line from the main board if the BL_ON is being held LO by the main board, it will not allow the BL_ON to go HI using the resistor.
                        • C152Heavy
                          by C152Heavy
                          Summary for TL-DR readers:
                          • VCC pin (18) of PFC...
                          01-11-2023, 02:53 PM
                        • dkneyle
                          Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                          by dkneyle
                          This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                          Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                          02-01-2022, 02:08 AM
                        • ngth82
                          SMPS schematic for Samsung UN46EH5000?
                          by ngth82
                          Good evening all!
                          I'm currently working on a Samsung UN46EH5000 TV.
                          I'm looking for the SMPS schematic for it. Does anyone have a source they can point me to? I looked on ElektroTanya and Tom's Service manual's sites, but i didn't see it.
                          I got the TV for $10. The unit worked, but 26 of the 44 back light LEDs were blown (all shorted). Looks like that is common with this model. Using my LED tester, it shows a Vf=2.6-2.7V.
                          I replaced all of the LEDs with SMD parts that I have. The rated Vf=2.9V on these units.
                          Right...
                          11-17-2019, 11:14 PM
                        • ohren
                          by ohren
                          09-08-2023, 05:24 PM
                        • brucetv
                          Samsung stooping to a new low
                          by brucetv
                          Well, just snapped the back on another piece of crap less than 2 year old Samsung after giving the customer the bad news that the lower panel driver boards have so many shorts its not recoverable. Now if your tv takes even a subtle surge it not only takes out part of your main board/tcon board it keeps on going right into those lower panel driver boards and the customer doesn't want to pay my hourly fee to find shorted caps in parallel, fried resistors, and shorted diodes. We really started to see them roll in like this in the KS,MU,NU, RU, and now QN series Samsung's it seems they are deliberately...
                          08-08-2021, 01:34 PM
