samsung LA 22A450C1
  • aanan
    • 222
    • India
    samsung LA 22A450C1
    samsung LA 22A450C1 [BN64-00803A ] no diplay smps on 13.5v present.red led glowing i dont no inverter circuit i need schematic.
  • aanan
    • 222
    • India
    Re: samsung LA 22A450C1
    anyone please.
    • aanan
      • 222
      • India
      i upload board image.
      • Rtech
        • Jul 2010
        • 1095
        Check Inverter transformer secondary windings for resistance.
        • selldoor
          Slow Learner
          • 7870
          see here for pin out - no power to board - meter on ohms 2000
          test s1 to s2 an s3 to s4 and post results.
          http://lcdparts.net/TransformerDetai...ProductID=3721
          Also test that green torpedo fuse F301
          • aanan
            • 222
            • India
            Friend Rtech & selldoor.
            i check fuse it is ok.
            TR pinout s1 to s2 1.023 ohms s3 to s4 1.023 ohms
            i suspect inv osc ic i need ic pin voltage.
            Thanks for reply.
            • Rtech
              • Jul 2010
              • 1095
              That is the Green fuse you have checked ?????,also have you checked the Backlights ??
              • aanan
                • 222
                • India
                i checked fuse & backlights.no output hi voltages inv transformer.
                Thanks Rtech.
                • aanan
                  • 222
                  • India
                  Thanks Rtech.
                  Please schematic upload.
                    Can you read the P/N of the SMD PWM IC and the MOSFETs which drive the inverter transformer?
                    Also check the DC voltage on that connector where the wires go to the logic board, I can see the labeling but cannot read them. We need to find out if the inverter circuit is getting the inverter_on (BL_ON) signal or not.
                    • viziks
                      • Mar 2012
                      • 33
                      • India
                      Thanks for reply.
                      This does not seem to be an Inverter issue at all.
                      This is a TV and not a standalone Computer monitor,when you power on the power led should blink and come on.Connect AV signals and after power on keep pressing source(Input select) on remote,if TV is working with signals connected you should be able to hear the Audio.
                      I suspect the Logic board is defective which is a known failure for this model.Check 3V3,5V and 1.5V on the logic board and if all voltages are present suspect defective main board.
                      On this model I was not able to bring on the Back-lights by pulling up the pin from 5v on logic board.
                      I have recently repaired this TV motherboard with the same problem of No operation except power led blinking when operating with remote or panel switches.
                      Just heated the metal shielded box which has the micro processor ICs.
                      Samir
                        "On this model I was not able to bring on the Back-lights by pulling up the pin from 5v on logic board." if you do not disconnect the BL_ON line from the main board if the BL_ON is being held LO by the main board, it will not allow the BL_ON to go HI using the resistor.
                          09-07-2024, 05:50 AM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
                          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 06:20 PM
