CTX S176A Clicking Monitor Repair
  • rrm
    • Dec 2013
    Thanks for all the help in the forums from all the contributors. Here's my contribution, hope it helps someone out there.
    Fault
    Monitor powers on, image is displayed for a second then monitor clicks and goes blank, come on for a second, clicks and goes blank. This cycle repeats infinitely.
    Details
    There is a power board inside the monitor, S9 Series Power Board rev 1.0a, 11S92-008A. S9-P08A10-1103.PCB are all the markings I could find on the board.
    Solution.
    Replace the six capacitors on the circuit board nearest the two transistors attached to the heat sinks.
    They are
    C21 - 1000uf 16v (CPC Part Number - CA07465)
    C22 - 1000uf 16v
    C20 - 470uf 16v (CPC Part Number - CA7468)
    C17 - 470uf 16v
    C15 - 1000uf 10v (CPC Part Number - CA7459)
    C16 - 1000uf 10v
    Someone posted some information about these capacitors and ripple currents so as the first batch of caps I ordered had far lower ripple currents I didn't try to use them. These are very close in value to the originals.
    So far I have repaired two monitors and both are now working perfectly. The outer casing was a little hard to open and does result in some damage, but the monitors are now working.
    RRM
  • rrm
    • Dec 2013
    Re: CTX S176A Clicking Monitor Repair
    quick update.
    Tested one with the Panasonic lower ripple capacitors and they also resolved the problem.
    Anyone got any thoughts?
    • rrm
      • Dec 2013
      Another update.
      Opened my forth monitor and this one has different caps. It has 4x1000uf 25v Teapo caps and 2x470uf 25v ?????
      Any thoughts, all labels are the same on the board. The fault is slightly different in that the monitor only flashes once and the green power light stays on but there is no image.
      Thanks in advance.
      • Rtech
        • Jul 2010
        • 1095
        Standard fault finding...caps if fau;ty, measure voltages of PSU,resistance of the inverter transformers...ie follow the 2 secs to Black sticky.Also as you have other monitors then it should be easier to solve by comparing voltages, resistances, and even swapping the screens, to check the backlights.
          by momaka
          03-15-2023, 10:17 PM
        • wattage
          by wattage
          Hello Badcaps Community,
          07-13-2025, 04:41 PM
        • ant3202
          HP 27es - LED monitor - Monitor Flashing On - Off
          by ant3202
          Hi Everyone
          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
          https://www.badcaps.net/forum/troubl...lashing-on-off
          The monitor is HP 27es LED Monitor
          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
          The monitor will randomly blackout and display no signal and will recover again.
          Sometimes need to power and off again to restore the display but...
          03-20-2025, 07:30 PM
        • Rick_1234
          by Rick_1234
          Good evening, gentlemen.
          Things I tried
          06-22-2024, 04:44 PM
          Wise Wing F199 19'' LCD monitor - recapped
          by momaka
          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
          When I saw the Craigslist post, I wasn't...
          08-24-2020, 10:58 AM
