Dell 172FPb
  • Arjay
    • Mar 2007
    Dell 172FPb
    I have the same old problem, ie flashing green light. I have replaced Q759 & Q760 which have both shorted once again after a very short while, as seems to be the norm.
    I see that there are multiple posts on this same fault, so! has anybody out there achieved a PERMANENT repair. The fault is obviously not the transistors. Has anybody tried interchanging transformers to see if the fault moves, and what is this FU90224N about? How does it come into the picture, and where is it anyway?
    Has nobody received any response from either Dell or Benq. This is obviously a design fault with so many units packing a sad!!
  • Galvanized
    • Mar 2006
    • 468
    Re: Dell 172FPb
    Welcome to Badcaps! I am not the expert here, just the bus-boy, but I can offer a little.
    Did you read this thread? https://www.badcaps.net/forum/showthread.php?t=1303
    These are good guys and can offer help/parts. They do sell on eBay as well.
    http://www.lcdrepair.us/
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • popzeggey
      Dell Latitude E7450 Power issues and fault
      by popzeggey
      I have a dell e7450 that shuts down abruptly when on and tries to restart. When the laptop attempts to restart, the hdd and wifi led is solid but power/battery led blinking hdd. Fault Description The memory modules are detected but encountered an error.
      I have tried all basic troubleshooting steps like removing the battery and pressing power button for 30secs but issue persists. I have tried different fully working rams but issue persists. Any help would be much appreciated
      01-16-2025, 04:31 PM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
      Dell Thunderbolt Firmware
      by SMDFlea
      Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
      Some models have a choice of 2 different firmwares, it depends on the dell SKU.
      The SKU is in brackets (****)
      EDIT: NVM65...
      01-26-2025, 06:22 AM
