Flickery Backlights in LG L246WH
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hello I have an LG Flatron L246WH Monitor that I got for free.
    At first It had a bad fuse, MOSFET, and diode. I replaced all and then it was working fine. A while later I took it in a trip in our trailer. It must have gotten bumped on the ride because when we got there there were no backlights. The lights would sometimes come on when I bumped the backside of the monitor. Now they will not come on at all. All of the caps and diodes are fine. The problem is on the power supply board because when I test it there is no 12v or 24v going to the inverter board. The bridge rectifier is good and so are the MOSFETS. I have taken the transfomers off but I don't know how to test them. I have a digital multimeter.
    Any guidance would be appreciated.
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • 1supertech
    • Apr 2012
    • 384
    Re: Flickery Backlights in LG L246WH
    check this site http://preher-tech.com/documents/tes...ormersinlcdtvs
    also check your CCFL bulbs one may be broken.
    • canadaboy25
      What is normal?
      • May 2013
      • 509
      My ccfls and trasformers are fine. The power supply board and inverter board are two seperate ones. My power supply board is not outputting 12v or 24v to the inverter board. I took the transformers off of the power supply board and wanted to test them with a multimeter.
      canadaboy25
        I doubt it very much that it is bad transformer, since you can bump it to make it come on before and now it is dead, I would inspect the solder joints closely. You should also check to see if you have 170vdc on the main cap right now.
        Do you still have 5V? Pictures of the boards?
        • canadaboy25
          What is normal?
          • May 2013
          • 509
          I re-soldered all of the through hole components and now it is working.
          It must have been a craked solder joint.
          canadaboy25
            Glad to hear it is working now.
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
