ASUS VE247 Help
+ More Options
Posts
  • aarynb1
    • Nov 2013
    • 31
    • usa
    ASUS VE247 Help
    Hello everyone, I recently got an ASUS VE247 monitor for free because it was going to be thrown away. It would work fine for a while and then the image would freeze up, lines would appear and it would start turning white. I opened it up to have a look and I couldn't find anything wrong, and I left it apart for a while to see if it would mess up so maybe I could find the problem, but it never would. So I started to put it back together and after I did, it would not turn on at all, so I was hoping I could get some help here because it would be a nice monitor if I can get it working.
    Here are some pictures of the PCBs.
  • aarynb1
    • Nov 2013
    • 31
    • usa
    Re: ASUS VE247 Help
    Can anybody help me out? I've looked at the pcbs and cant seem to find anything wrong. I can post more pictures if needed.
    • newtothis
      • Mar 2013
      • 1556
      • england
      Re: ASUS VE247 Help
      Ok so it would turn on before messing with it but now won't?
      Have you checked your connectors?
      • aarynb1
        • Nov 2013
        • 31
        • usa
        Re: ASUS VE247 Help
        Yes, I have checked the connectors with a multimeter and there was no power.
        • newtothis
          • Mar 2013
          • 1556
          • england
          Re: ASUS VE247 Help
          Just to make sure you tested it correctly... Set DMM to 20Vdc and put black probe to chassis (screwhole or something is good) and red into each of the pins on the connector that goes to the mainboard. Post results back like this
          pin 1 - 0v
          pin 2 - 5v
          pin 3 - 0v
          etc
          etc
          • aarynb1
            • Nov 2013
            • 31
            • usa
            Re: ASUS VE247 Help
            Ok, so I tested all the pins and got 0v on all of them. The components I circled in the image are pico fuses right? because I tested them and the ones I circled were bad.
            Thanks for your help
            • newtothis
              • Mar 2013
              • 1556
              • england
              Re: ASUS VE247 Help
              those are SMT caps... prefix is cXXX
              Fuses will be FXX/16A or similar
              Check your main fuse... the big one next to the large capacitor.
              If ok check voltage at main cap, probe on each lead
              • aarynb1
                • Nov 2013
                • 31
                • usa
                Re: ASUS VE247 Help
                Ok, the fuse was good, I got 381v while it was plugged in, and 97 while it was off.
                  Re: ASUS VE247 Help
                  "381v while it was plugged in, and 97 while it was off" That cannot be right, when it is off, you should have around 160~170VDC right at the two legs of the main cap.
                  • aarynb1
                    • Nov 2013
                    • 31
                    • usa
                    Re: ASUS VE247 Help
                    Oops... had the multimeter set to AC lol. I got 173v while it was on, and 40v while it was off.
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      Re: ASUS VE247 Help
                      Those are way off, the chances of that cap being bad are slim!
                      Check your meter battery
                      • aarynb1
                        • Nov 2013
                        • 31
                        • usa
                        Re: ASUS VE247 Help
                        I used a battery tester and it said it was bad, so I guess ill have to get a new one tomorrow and try it again. Is there anything else to check for right now?
                        • aarynb1
                          • Nov 2013
                          • 31
                          • usa
                          Re: ASUS VE247 Help
                          Did you see this post though, I retested it because I had it set to AC.
                          • newtothis
                            • Mar 2013
                            • 1556
                            • england
                            Re: ASUS VE247 Help
                            Yes i looked at that post, As budm said it should read 160~170Vdc so 40Vdc is way too low, hence i asked about your meter battery
                            • aarynb1
                              • Nov 2013
                              • 31
                              • usa
                              Re: ASUS VE247 Help
                              Ok well thanks for the help, ill get a new battery and test the cap again, and report back tomorrow.
                              • aarynb1
                                • Nov 2013
                                • 31
                                • usa
                                Re: ASUS VE247 Help
                                Ok, I got a new battery for my meter today and checked again. I still got 170vdc while it was plugged in, and 44vdc while it was unplugged, is it possible the cap is bad?
                                  Re: ASUS VE247 Help
                                  "44vdc while it was unplugged" that is because the cap was diacharging when the power is removed (not plugged into the outlet).
                                  So reading at 170VDC when plugged in is OK.
                                  • aarynb1
                                    • Nov 2013
                                    • 31
                                    • usa
                                    Re: ASUS VE247 Help
                                    What should I check next? I double checked and the logic board is still getting no power, all the components look good.
                                    • aarynb1
                                      • Nov 2013
                                      • 31
                                      • usa
                                      Re: ASUS VE247 Help
                                      Sorry for the bump, but its been a while and no one has posted. Can anyone help me out? I can upload more pictures if needed.
                                      Thanks.
                                      • aarynb1
                                        • Nov 2013
                                        • 31
                                        • usa
                                        Re: ASUS VE247 Help
                                        How would you check the transformer I circled? I tried to check it and I got 170v on one side, and 0v on the other, but im not sure if I did it right.
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • myth77
                                          ASUS PG27U MONITOR
                                          by myth77
                                          First, i dont work on monitors only on laptops and that also for a hobby. So, i received this monitor in the title and it was completely dead, and power supply when used was going off to a power protection. I found that one of the voltage regulators for backlight GS9238 is dead, so i replaced it and monitor is working fine now. But...on the main motherboard first thing i tested was a main power rail and after power jack there is one mosfet Nikos PD537BA. The thing is when i tested all pins of that mosfet are shorted in between. Now when i plug the adapter the monitor just goes on. I dont think...
                                          03-19-2024, 08:58 AM
                                          ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                                          This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                          09-07-2024, 02:50 AM
                                          ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
