Asus LS221H - Power LED is blinking
  • -k2-
    • Nov 2013
    • 12
    I've trouble with my Asus LS221H LCD Monitor.
    When i put in Power, the Power-LED is blinking. I can't switch off the monitor.
    I've disconnected the CCFL board => same problem.
    I've disconnected the Screen => same problem.
    I've disconnected Screen and CCFL board => same Problem.
    So the fault is probably on the board in the stand.
    I suspect one or both regulator "1084 PE 025H1" are faulty, because I can hear a very faint whistle from the field.
    Has anyone an idea how I can check this, or what else could be faulty?
    I have a multimeter (Amprobe AM-240)
    I thank you in advance for the help.
    Re: Asus LS221H - Power LED is blinking
    I would check those cap for capacitance and ESR. The TOROID with blue core is switching power supply with two caps next to it, check those caps also, that TOROID is more likely the one that is making noise. Have you already verify that the external power supply is OK?
    • -k2-
      • Nov 2013
      • 12
      I've checked the two caps.
      They should have 330uF, and they have 359uF and the other one 360uF.
      I don't know how to check ESR with my Multimeter (AFAIK i need an ESR meter for that).
      External power supply is ok.
      • -k2-
        • Nov 2013
        • 12
        I've added a mp3-file (packed as ZIP-File). There You can hear the "whistle" (and Background noise).
        It's around the "1084 PE 025H1" regulator. I can't locate the exact position from where it comes, because it´s really very faint.
        I also measured a little, and found that at Q2 and Q15 the voltage jumps between 3,34 and 0V. In the same clock as the whistle.
        I've added a picture, with the voltages from Q2 and Q15.
        All but power supply disconnected. It's the same.
        (PS: sorry if my english is nod good, but i think You'll understand what i mean)
        • -k2-
          • Nov 2013
          • 12
          I've changed all the caps (4x330uF 4x100uF).
          So we can exclude these.
          I have measured some voltages (see pictures).
          [e.g. 3.34V/0V means, that the voltage jumps between 3.34 and 0V]
          Maybe it helps somehow.
          I already fear that the EEPROM or serial flash is faulty.
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • ShadowAi
            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
            by ShadowAi
            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
            03-15-2024, 10:46 AM
          • meraklinetx
            Asus Z97-a power cycle, no boot no cpu voltage
            by meraklinetx
            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
            05-10-2023, 06:08 AM
          • Duranitron
            Asus x512dk rev 2.1 power on problem
            by Duranitron
            When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
            Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
            11-26-2024, 10:22 PM
          • Thomas Smith
            Asus Tuf gaming fx506l no power, mosfet does not open
            by Thomas Smith
            Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
            Initial Symptoms:
            • The laptop has no power at all (no LEDs, no fan spin).
            • No 3.3V or 5V present on the board.
            • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
            Power Rail Checks:
            1. Charger input (FETs PKCH2BB)
              • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
            2. BQ24780S Charger IC:
              • VCC and ACDET are present.
              • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
              • Shunt resistor has 10Ω to ground.
            03-30-2025, 03:38 AM
