Dell E172fpb
  • samykenza
    • Feb 2007
    • 7
    Dell E172fpb
    I have a problem with an LCD Dell E172fpb! I take some pic :
    this is what it should display :
    and this is what it display :
    this another exemple :
    and here what I got :
    thanks a lot for any help
  • TOMARRO
    • Jan 2007
    • 10
    Re: Dell E172fpb
    It might be a ribbon-cable problem. The cable might be loose, but it's not likely.Have you test with another monitor and the same VGA video card cable?
    Sometimes is only a bad connection of a pin in the "flex band".Others is the video chip on AD board, press on it, but be careful!, (don't break anything in the process.)
    Perhaps,you may need to replace your wiring.
    • samykenza
      • Feb 2007
      • 7
      Re: Dell E172fpb
      all cble are ok!! I tasted also all component on th AD board and it seem be ok also!!! I think it's the chip on the AD Board!!! or may be cause the Ad Board can't get the correct voltage from the inverter board!! but I need the correct value to compare with mine.
      • supersabre
        • Feb 2006
        • 45
        Re: Dell E172fpb
        I heard some of the Benq LCD has capacitor probelm. The cheap lelon cap's esr is way too high and causes all sorts of problem. Also, cold solder joint is very common in Benq.
        • gonzo0815
          • Feb 2006
          • 1600
          Re: Dell E172fpb
          Well i assume the vid proc is using 5v, so make shure there anren`t any badcaps on this voltage andon the AD board. And examine the solder points of all comonents closly. may be there is a pin not soldered corectly.
          • TOMARRO
            • Jan 2007
            • 10
            Re: Dell E172fpb
            If it helps?
            in my Benq FP731 (conector CN701) I read this voltages.
            stanby running
            TP 20--------0'07 V 0'07 V
            TP 19--------0'00 V 3'30 V
            TP 21--------0'00 GND 0'00
            TP 22--------0'00 GND 0'00
            TP 23--------4'97 V 4'87 V
            TP 24--------3'30 V 3'30 V
            TP 25--------0'07 V 0'07 V
            TP 26--------0'00 V 0'00 V
            • picco
              • Nov 2008
              Re: Dell E172fpb
              Originally posted by TOMARRO
              If it helps?
              stanby running
              Hi Tomarro, I have the board benq 48.L0J01.A00, I need the pinout of the power supply connector, as you wrote above.. you can help me?
              thank you for support and sorry for my english...
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • F R 2568
                Dell Latitude 5420 does not start (no post) need help to find the reason why
                by F R 2568
                Hello all,
                this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                If the laptop is only connected to the AC adapter (battery removed):
                When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                The power/battery...
                01-08-2025, 05:45 AM
              • diamon
                Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                by diamon
                I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                Pictures of these boards:
                Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                Dell...
                02-28-2024, 12:51 PM
              • OntarioTL
                Dell 5410 greyed out BT
                by OntarioTL
                Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                Dell Lattitude 5410
                Service Tag...
                Yesterday, 01:28 PM
              • lalle-
                Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                by lalle-
                Hello!
                I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                08-11-2024, 02:01 PM
