Hanns G HW173A 2 seconds to Dim
  • Number 47
    • Aug 2013
    • 19
    • Ireland
    Hello. New here and looking to learn, I'm hoping there is someone who will have the patience to help a newcomer to electronics. I got this monitor for free after it went Dim and I'm hoping to get it fixed for my daughter so she can use it with a desktop I am building.
    I'm currently re-training myself due to the economic collapse so I have no resources for repair bills or new monitors. I would certainly appreciate all advice and assistance.
    When I power on this monitor it shows a good picture for 2 seconds then goes dim, I can just see the images and menu. I have read a few posts about this on this site and others and then I came across the 2 second to black troubleshooting guide. I have tried to follow it but I am past my capabilities. I learn best by doing so I hope someone will take the time to assist.
    So far I have disassembled the unit as far as the ccfl tubes, everything looks ok, there was one cap that looked a bit bulgy at the side but when I removed it and cut away the plastic cover it was fine underneath. I replaced it anyway. Same result on firing it up.
    I have a cheap multimeter and a few spare ccfl tubes from some old HP laptops that met the nvidia issue.
    A few pics,
    Hope I've done that right,
    I've been trying to follow the troubleshooting guide for this issue but I'm getting results nothing like expected. I'm wondering if my multimeter is wrong? More likely I'm doing something wrong.
    Humbly
    Jon
  • Rtech
    • Jul 2010
    • 1095
    Re: Hanns G HW173A 2 seconds to Dim
    On the right of your Power Board there is an Inverter transformer labeled T901.On the underneath side the Board it is marked with two sets of arrows, one pair at each end of the transformer.Put your meter on to the resistance Range (Ω) 2000,and with NO POWER attached measure between the top pair and then the bottom pair and advise the readings.
    • Number 47
      • Aug 2013
      • 19
      • Ireland
      Thanks rtech.
      I've done that and I'm getting 574 each pair.
      I was thinking about this last night, I assumed the ccfls were ok because they were firing for a few seconds but having read a few threads I am starting to realise they could still be the problem. There is slight blacking on the end of the tubes. I will dig them out again and post up some pics.
      Thanks for your help.
      • Rtech
        • Jul 2010
        • 1095
        You have some Hp ccfl's no doubt with different connectors from this board, but you may well have to hard wire them in to confirm lamp fault or not, and which ones.
        • Number 47
          • Aug 2013
          • 19
          • Ireland
          Yes, different connectors, I have 2 17" screens from DV8000 laptops, the plugs are much smaller, I've removed the plugs from both and will swap the plugs over. Testing one ccfl then the other.
          I have 1 pink wire and 1 blue wire on the hp, 1 pink wire and one white wire on the hanns g. Both the pinks are marked with a blue dot (hanns g and HP) I'm assuming I can test using the white in place of the blue. Is polarity important on ccfl?
          Many thanks.
          • Rtech
            • Jul 2010
            • 1095
            Thr 'hot'one is usually the thicker one,in most cases with monitors and Tvs they are paired as pink & White......Blue and black...so it would seem you have it right.You must test with 2 sets of lamps in ie one original,be it top or bottom and one test set.Also as heat rises the top set fail more than the bottom so that is probably the one to test first.
            • Number 47
              • Aug 2013
              • 19
              • Ireland
              An update,
              I hooked everything up, both lights are lighting a third to half of the way up before cutting out. There is a fizzing noise coming from the area I marked in red when I put it in standby.
              Haven't torn into my HP screen yet to get the lamp out. Sorry about the inline pics at the first post folks, didn't realise I was doing it wrong. Hopefully I have cracked it now.
              • Number 47
                • Aug 2013
                • 19
                • Ireland
                So, tested the lamp this morning, swapped them both one by one, same result. Lighting half way. The fizzing sound I mentioned in my last post sounds like gas escaping?
                • Rtech
                  • Jul 2010
                  • 1095
                  These are older models so maybe both lamps have failed ??
                  • Number 47
                    • Aug 2013
                    • 19
                    • Ireland
                    I suppose it could be both, there's no guarantee the HP one is good either, it was working the last time I had it on.
                    I guess I'll have to make some kind of bulb tester. I've got some old componentry knocking around, time to build something I suppose.
                    Will report back.
                    Thanks for all the assistance Rtech, it's very much appreciated.
                    • Rtech
                      • Jul 2010
                      • 1095
                      One thing you can do, which might make things clearer, is to operate the monitor WITHOUT the lamps plugged in ie join the logic board to the psu and on/off control panel,and switch on..if there is no hissing, then the lamps are the first suspects..
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Listen to transformer T901 to see if it is hissing.
                        I would replace all the electrolytic capacitors too, the one you put in is a crap brand too!
                        Muh-soggy-knee
                          Light half way, that means the drive circuit is not putting out enough voltage to drive the lamps. How is that Dual MOSFET (the one with tab on top and 5 legs at the bottom (the middle leg is trimmed))? P/N?
                          • Number 47
                            • Aug 2013
                            • 19
                            • Ireland
                            I have tried this now, the whine/hiss is still there, except now it is there not only on standby, it is rhythmically whining when in operating mode too. I think it is coming from the coil I marked in red. When I cut power it slowly faded the noise.
                            • Number 47
                              • Aug 2013
                              • 19
                              • Ireland
                              Definitely not T901 making the noise.
                              The crappy cap is all I could get locally, online ordering means going overseas and waiting days for delivery. It is a holiday weekend here too so not a lot I can do. Must make do with the assorted pack of (same brand) caps I have to hand I'm afraid.
                              • zklgfs
                                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                by zklgfs
                                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                08-11-2025, 02:14 PM
                              • twonk9098
                                Lenovo Legion 5 high fan spin turns off after 34 seconds
                                by twonk9098
                                I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                I have tried a few new bios but exactly...
                                07-14-2024, 11:19 AM
                              • liquidzorch
                                Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                                by liquidzorch
                                Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                                10-18-2024, 05:19 PM
                              • Rick_1234
                                LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                by Rick_1234
                                Good evening, gentlemen.
                                I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                Things I tried
                                - Bought a new AC adapter thinking that was the problem but the problem...
                                06-22-2024, 04:44 PM
                              • PowellSkier
                                Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                                by PowellSkier
                                A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                                06-17-2024, 11:43 AM
