Recap or not to recap
  • 1supertech
    • Apr 2012
    • 384
    Hello fellow techs
    I just recived three monitors NEC ASLCD92VX-BK 19" monitors are healthy and working fine, caps on power supply are United Chemi-con ky series they all test fine on ESR meter, I don't know how old they are should I recap all monitors I sell monitors and I don't want them coming back for bad caps
    Thanks all
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Recap or not to recap
    KY series caps are amazing. They will be fine. If CapXon/Lelon, etc. caps can last years in monitors, then those will be good for a very long time. Other components will die long before those caps do
    • retiredcaps
      • Apr 2010
      • 9271
      KY caps are good. No "known" problems.
      --- begin sig file ---
      --- end sig file ---
      • 1supertech
        • Apr 2012
        • 384
        Thanks all thats what I thought also
          I would leave them alone and see how long they will last, that will be real life test.
            by momaka
            03-12-2025, 03:42 PM
            by momaka
            03-15-2023, 10:17 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
            no-name Radeon 9600 XT recap and cooler
            by momaka
            I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
            This one was actually suggested to me by ChaosLegionnaire....
            11-06-2020, 07:54 PM
            ASUS P5GC-MX motherboard recap
            by momaka
            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
            So here is what the motherboard looked like with its original caps:
            CPU VRM area up close…...
            01-27-2021, 11:59 PM
