Dell P2210f no power
  • jrcollins
    • Jun 2022
    • 7
    • New Zealand
    Re: Dell P2210f no power
    As for the schematic it seems a bit of the right of the paper got cut off when it was produced.
    But it can be inferred that you should have a +16v for the backlight, and then +12v and +5v for the logic on that connector.
    I was going to start another thread but seeing as you have already addressed this question, I was hoping you might be able to offer some clarification.
    Do you know which wires I need to test for the 12v and 5v you mention in your reply?
    Sorry for the poor quality of the photos.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Your photos are not usable, here is what I used instead: https://www.badcaps.net/forum/showpo...3&postcount=30
      I made one omission in my previous post: 12v does not seem to be for that connector (CN851), it is for the DC jack at the bottom.
      So you have that, and then +16v for the backlight driver (not easily accessible, can measure at J2 or R871 on side facing PCB edge).
      The 5v is then accessible on the bottom 4x pins where the one red wire is (very strange color coding!) and ground is the two pins above that.
      All the rest are for various signals like On/Off control, backlight control, audio detection on/off etc.
      Note that diodes D854 & D855 that you are changing only supply the +16v for the backlight, it is separate from the other voltages!
      • offs3l
        • Feb 2023
        • 3
        • spain
        Hi
        I have the same problem. Should I open a new thread?
        In my case I changed D881 because it was bad but that didn't solve my problem. I have 0 volts after C889 and I850. Does it mean that one or both of them are bad?
        I attach an image to clarify
        • zlr8r
          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
          by zlr8r
          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
          Ill try and give as much info as I can.
          Dell Inspiron 17 (7786) Laptop
          Service Tag: 5J0NHT2
          Bios: 1.9.0
          When I received this , it would only flicker on the KB backlight for a second, then off and on.
          Then it started getting weirder!
          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
          12-12-2023, 09:31 PM
        • LimesKey
          Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
          by LimesKey
          Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
          10-17-2025, 05:33 PM
        • seppde
          Dell XPS 9380 No Power - After providing 3VALW and 5VALW once, they persist - still no power-up
          by seppde
          I've recently gotten my hands on a defective XPS13 9380. I will attach a zip of the schematics and boardview.
          My first discovery on the Board was that the reverse current Diode PD103 of the 1st USB-C was blown.
          Nothing to worry about, the board got 3 USB-C ports which support Power/Charging. On I go.
          Next I inspected the power-rails to see why the diode blew up and found a short on the 3V3 rail which I traced back to the Power-IC for the LCD (UZ2). I desoldered it and the very low-ohmic short is gone. I checked on the LCD-connector that there's no short...
          10-01-2024, 10:57 AM
        • khelane
          test active pfc power with lamp test
          by khelane
          Hello
          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
          Is there a way...
          06-03-2025, 01:00 AM
        • SuperJames
          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
          by SuperJames
          This one's a weird one, and still unsolved despite it having gone back to Dell once.
          Specs
          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
          Backstory
          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
          10-23-2023, 04:09 PM
