low esr caps for lcd inverter
  • klein
    • Nov 2008
    • 37
    hi
    i came across a couple 19" cheep lcd tv's both exactly the same and both with electronic problems. i had no use for tv's so i wonted to make them monitors, on ebay you can buy controller board and lcd inverters. so i bought two and they worked out great Except after a mount or two they started flashing when you turn them on, one did it first so i contacted the company i bought it from and they sent me a new lcd inverter. i installed it and now the other one is starting to do the same thing. so my though is each inverter has 2x 220uf 25v 105c caps on them and i'd like to replace them.
    controller board are 12v
    the new lcd inverter has two shcon caps witch state right on them low esr but i can't find shcon caps listed anywhere.
    the lcd inverter that i have out that blinked has hy 220uf 25v lesr 105c
    i need a good cap 220uf 25v lesr 105c
    i was looking at these but they don't say low esr on them
    Rubycon ZL 25v 220uF -40 to 105C 8X11.5mm p# 25ZL220M8X11.5
    Rubycon ZLG 25v 220uF -40 to 105C 8X11.5mm p# 25ZLG220M8X11.5
    i have two caps here marked with an m in a box marked 220uf 25v 105c FM
    who makes the caps marked with an (m in a box)?
  • sabre504
    • May 2010
    • 449
    Re: low esr caps for lcd inverter
    You can use panasonic FC or FR as replacements both are low esr
    • klein
      • Nov 2008
      • 37
      if i'm going to have to order them i'd rather order rubycon is either of these two the right one's ?
        " have two caps here marked with an m in a box marked 220uf 25v 105c FM" That sounds like PNASONIC FM series which is what I use.
        Rubycon:
        http://www.rubycon.co.jp/en/catalog/capacitors.html
          by momaka
          03-12-2025, 03:42 PM
        • ajdrenter
          Picking caps for Antec SU-380
          by ajdrenter
          In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
          https://www.badcaps.net/forum/showthread.php?t=14159
          It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
          05-13-2023, 10:40 AM
        • JFA
          Honda generator inverter 230v 1900uf caps
          by JFA
          I have a Honda generator with a faulty inverter. The inverter is encased in black resin with just the tops of a dozen small electrolytic caps and four 230v 1900uf electrolytic caps poking out of the top of the resin. The plastic cover of one of the 230v caps was burned off but there was no sign of bulging and the capacitor can was in good condition. The heat source looks likely to be from the outside rather than from the component itself but since the inverter is basically unrepairable, I chiseled away and removed the capacitor. I had to destroy the capacitor so had no chance to test it but it...
          11-28-2021, 03:30 AM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
