LG Studioworks 775N monitor
    Hello All,
    I have an LG Studioworks 17 inch CRT monitor, model 775N. It is currently sitting in my shed. It was working fine a few months back, then one day, it started to click in operation, a few times actually, so i turned it off, then i went to turn it back on and it wouldnt turn on. It just clicks .... very loudly.... i can hear it degauss itself on bottup , then it will just click and turn off, and automatically reboot and do it all again, nothing comes onto the screen now, just a blackness. I was lucky once to get the words "Signal cable disconnected" for about 10 seconds, and it automatically turned off again, with the standby light in Amber.
    Im guessing that my flyback circuit is busted forever now?
    Thank You
    Re: LG Studioworks 775N monitor
    most likely PSU EHT as you suspect pm you some info
    hoping you haven't killed EHT
    Be careful in there, nasty bites or terminal case of "dead" possible
    even with plug removed
    HTH
    cheers mate
      Will there seriously still be power in there?! it's been unplugged since April 2006.... wow, that thing must be like a battery....
        Really was talking about when you replace things power it up turn it off cause it didn't work and go poking around inside
        but yes somethings can hold a charge for quite a while
        (ok maybe not months)
        The tube is a very good capacitor (of sorts) and when charged up from the EHT at about 25,000 ~30,000 Volts (25KV~30KV) can have a very high voltage stored across it
        See here
        When dealing with CRT EHT or SMPSU
        Always follow correct Safety procedures
        Basically not really a place for people with little knowledge to be in which is why the warning above.
        suggest you go here to read more about them and the safety section.
        This will give you an idea of how the TV works, crt monitors are basically the same but have different application and therefore are somewhat different in how they process the video signals and display it.
        monitors
        SMPSU
        I would probably just check, replace regs etc as outlined in PM
        but if its the EHT ....bin it probably not worth the cost of fixing
        Hope this helps
        CRT Monitors TV's and SMPSU all have a potential to Kill you so please treat them with the respect they deserve
          See here
          monitors
          SMPSU
          Hope this helps
          Just an update.... Well I got rid of the LG CRT monitor earlier this year and got a replacement Diamond View 1770G 17" CRT monitor.
          Anyway, thanks for the advice Starfury1.
          Thanks.
