Dell 2007fp inverter problem
  • leapius
    • Aug 2012
    • 60
    My Dell 2007fp has a defective inverter board. Occasionally (once a day and usually when it's warmed up, then turned on from power saving mode again) the backlight will flicker for around 5-10 seconds and then go back to normal brightness.
    Fortunately I have another working 2007fp and swapped the inverter boards around, which moved the flickering problem to the other monitor so I think that proves it is indeed the inverter board at fault.
    I recapped it with Rubycons but there was no change. Each inverter winding has roughly the same resistance as the equivalent one on the functional board.
    Any ideas what's causing this and what I can do next? It's very hard to tell but the bottom bulbs might be *slightly* dimmer when it's flickering but not sure.
    Thanks in advance.
  • selldoor
    Slow Learner
    • 7870
    Re: Dell 2007fp inverter problem
    Does it do it if you have the brightness turned down a touch?
    Could try removing the old solder from the transformers and re-soldering with new leaded solder. Same goes for the joints on the blue high voltage caps and the actual bulb sockets.
    Someone recently had a bent pin in the socket?
    • leapius
      • Aug 2012
      • 60
      Brightness doesn't affect the problem I don't think. Thanks for the advice - I will reflow all those joints, check the sockets and get back with my results. I guess it could be a dry joint as it never seems to do it from cold, only when it's heated up a bit then turned off and on momentarily.
      • leapius
        • Aug 2012
        • 60
        Ok so I reflowed all the joints on the transformers and high voltage caps. It is still exhibiting the same problem. Any ideas what could be causing this issue? High voltage caps? I'm all out of ideas, help!
        • toti24
          (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
          by toti24
          dell precision m4600 laptop
          i7 2760qm
          8gb ram 750gb HDD
          intel hd 3000 integraded and nvidia quadro 2000m
          pleasea bear with me english isnt my language and ill try to be as clear as possible
          note i live in mexico in a very small town..
          thank you.
          laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
          the brick happened when i was installing win 10 using usb.
          used rufus and officia microsoft.iso
          it finished copying files from usb...
          03-06-2022, 08:39 PM
        • SDNarcia
          Dell 15R-5521 keyboard problem (KBC?)
          by SDNarcia
          Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
          As additional information,...
          07-20-2024, 10:47 PM
        • Achille15
          Dell N5110 problem
          by Achille15
          so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
          03-29-2025, 04:41 PM
        • masoksian
          Dell latitude e7470 not turn on .power buton on off and Run Power problem
          by masoksian
          I am dealing with the problem of turning on and off my Dell e7470 notebook.
          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
          The system does not turn on, there is no post.
          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
          The problem continues in the same way.
          I tried to turn on the Fn key, nothing came to the screen....
          02-15-2025, 12:08 PM
        • MahmoudNasser
          Dell 7480 problem with freezing during the Windows loading process
          by MahmoudNasser
          Hello everyone, I wish you a happy day.
          I have a Dell Latitude 7480 laptop that has a problem with freezing during the Windows loading process. If it manages to boot up, it becomes very slow and doesn't load anything from the desktop.
          Device Data
          Model Dell Latitude 7480
          CPU:i7-7600U
          SN:7T58PL2
          MP PartNumper:CAZ20 LA-E131P Rev:1.0 A00
          Bios Chips:W25Q128BV
          The attempts that have been made to solve the problem have not yielded any results.
          1. Changing the M.2 and M.2 Nvme hard drives.
          2. Trying...
          07-09-2023, 05:04 AM
