EMPREX LM-1905 will not turn on
  • dannycelluk
    • Apr 2013
    The monitor will not turn on, have checked the power cable and the VGA cable both are fine.
    The power on LED seems very dull and then goes out after a little while so i am assuiming there is a problem with the supply?
    I have disassembled the monitor and on what appears to be the PSU PCB board, I have noticed that there are various caps that are buldging. So i intend to replace these. I have also checked the internal fuse which appears to be fine also.
    2 x 10v 1000uf
    2 x 25v 680uf
    2 x 25v 220uf
    2 x 25v 470uf
    2 x 450v 100uf
    2 x 25v 47uf
    2 x 16v 470uf
    2 x 16v 22uf
    I have also notice a discolouration of the PCB board under two of the caps and two of the IC's.
    I was going to install a chip holder and replace the two IC's which are 4511GED but i cant appear to source these from anywhere?
    Does anyone know where i can source these IC's or a like for like replacement?
    I will post pictures when i get home but i am unable to do this at present.
    Cheers
    Dan
  • twbranch
    Mad Nerd
    • Oct 2012
    • 153
    Re: EMPREX LM-1905 will not turn on
    We will wait on the pictures. I kind of doubt it is the ICs. Need to check those pictures before settling on the next action.
    • 1supertech
      • Apr 2012
      • 384
      2 x 10v 1000uf
      2 x 25v 680uf
      2 x 25v 220uf
      2 x 25v 470uf
      2 x 450v 100uf
      2 x 25v 47uf
      2 x 16v 470uf
      2 x 16v 22uf
      Cheers
      Dan
      Check this site http://www.utsource.net/ic-datasheet...D-1885942.html
      • dannycelluk
        • Apr 2013
        Cheers for the quick reply
        The board looks identical to the board posted here....
        https://www.badcaps.net/forum/showth...ghlight=EMPREX
        But the brown colouration on the board is next to the 2 caps on the right hand side next to the IC's on pic 3.
        • Rtech
          • Jul 2010
          • 1095
          Change the caps,and try it, would not worry about the brown colour at this time.
          • dannycelluk
            • Apr 2013
            ok thanks, ill give it ago on picture two above there are a group 0f 5 Caps over to top left hand side of the board, these do not look like power caps to me as they are next to the headphone jack, can anyone confirm? or shall i change these as well?
            • Rtech
              • Jul 2010
              • 1095
              Those can be left alone.
              regards
              • pajdek
                Lenovo Y700-17ISK turn on and off
                by pajdek
                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                09-20-2023, 02:49 AM
              • RdeveLabs
                MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                by RdeveLabs
                To all the members here...
                Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                05-05-2025, 04:59 AM
              • robante15
                Acer Aspire 4520 won't turn on after reboot
                by robante15
                Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                If I remove the...
                04-06-2024, 06:50 PM
              • masoksian
                Dell latitude e7470 not turn on .power buton on off and Run Power problem
                by masoksian
                I am dealing with the problem of turning on and off my Dell e7470 notebook.
                The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                The system does not turn on, there is no post.
                I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                The problem continues in the same way.
                I tried to turn on the Fn key, nothing came to the screen....
                02-15-2025, 12:08 PM
              • dqtech
                lenovo x240 nm-a091 wont turn on
                by dqtech
                i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                board number VIUX1 NM-A091 REV:1.0...
                02-07-2024, 01:57 AM
