Samsung Syncmaster T220 - bad caps?
  • Takeover
    • Apr 2013
    • 31
    Re: Samsung Syncmaster T220 - bad caps?
    well I don't have a solder gun anymore I had to give it back.
    Also as you can see in the picture I burned the insulation off the wires so I could use them.
    Do they have to be insulated.
    Is it possible if I just leave the existing wire in the terminal, take the wire and just crush it together in the crimp.
    Will I get a signal?
    • Takeover
      • Apr 2013
      • 31
      Hi guys it's me again. I haven't been here in 2 months. I was busy so I was not able to work on the project here.
      Unfortunately there are no stores around me that carry capacitors. I thought there were, but Radioshack closed a long time ago. I tried The Source, which is quite the drive away, and they carried a very small selection.
      Can anyone recommend a cheap online site that will ship to Canada?
      I would love to at least try to get this monitor working. It's in pieces just collecting dust.
      Also the solder gun I tried was not hot enough to remove the capacitors. How hot does it have to be?
      • Mrx3750
        • Jul 2013
        • 311
        Frankly I think the attachment system is slower, but whatever.
        OP I think you might have either a video board issue, or panel damage. I have never seen cable or cap failure produce an image like that, however panel defects and video board issues, that I've seen.
        • Takeover
          • Apr 2013
          • 31
          And I assume there is nothing that can be done about that?
          • Mrx3750
            • Jul 2013
            • 311
            You could try swapping the video board. Really the best way to know is to see if you could get ahold of an identical monitor and swap the panels and see if the issue pops up on the new one.
            Looking at it more closely, it seems that the issue facing your panel is very low color depth. This points to a video board issue. Can you test the monitor with an all white image?
            • Takeover
              • Apr 2013
              • 31
              I have the exact same monitor but if like I said... If I damage this one, I don't have the money to buy a brand new one.
              I already broke the cable that connects to the power button. So I can't even turn it on if I put it back together.
              I tried to take good screenshots but it doesn't really show it that bad.
              There were a lot of visible pixels and bright hues of green and pink. In the center it was bad.
              • Mrx3750
                • Jul 2013
                • 311
                Is it the same way on a white image?
                Since you have the same monitor, you have a way of narrowing down what the problem is. Likely swapping the video board (the one with the VGA and DVI (if it has it) port will tell you what the issue is. Just be careful and you'll be fine.
                • Carbonic
                  • Jul 2013
                  • 13
                  • Denmark
                  #48
                  Well, for most of us changing the video board will cost half the price of a similar monitor.
                  • Takeover
                    • Apr 2013
                    • 31
                    The monitor has just been sitting on my table for months.
                    I went to an Electronic store about a 1 hour drive and they don't even carry the right size capacitors. So I'd have to get them online.
                    I tried to look local for a power board since most of you said that's the problem, but no luck.
                    So I am not really sure what to do now. I don't feel comfortable taking apart my only working monitor.
                    Is there a place online I could find a power board? I still have to fix the power button wires I broke.
                    • Thermaltake
                      Brain badcap
                      • Aug 2015
                      • 332
                      • D12
                      #50
                      Hi, I have T220 for like 7 years or so, monitor is still working perfectly without any problems but lately I've noticed when I turn it On in the morning when monitor is cold I hear some buzzing inside and that buzzing is getting quieter after monitor is turned On 30 minutes or so, and after that I can't hear it at all anymore. Interesting thing is when I turn it On just monitor without PC in the morning and that Samsung logo is shown and after that Digital/Analog searching for signal, there is no buzzing not even when he is on stand by or turned off completely on button, but then when I turn my PC On buzzing starts. Monitor is connected with DVI cable, I tried another DVI and power cable but same thing, so it's not cables. I opened monitor half a year ago and PSU and everything else was looking OK, no bad caps or anything suspicious. So I was wondering could that be some bad cap/s or inverter buzzing if anyone know ?
                      • Thermaltake
                        Brain badcap
                        • Aug 2015
                        • 332
                        • D12
                        #51
                        anyone ?
                        • Thermaltake
                          Brain badcap
                          • Aug 2015
                          • 332
                          • D12
                          #52
                          I open t220 today, but everything looks okay there are no blown capacitors or anything suspicious. And still there is that buzzing noise when monitor is cold, and after 25mins it stops buzzing. I will investigate futher more these days, but if someone have any clue what that can be please write.
                            09-07-2024, 05:50 AM
                          • black6host
                            Replacement caps for Samson Resolv studio monitor 65A Amp board.
                            by black6host
                            Good day!
                            I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                            I'm going to replace the caps and I'll be the first...
                            02-06-2024, 08:22 PM
                            by momaka
                            03-15-2023, 10:17 PM
                            by momaka
                            03-12-2025, 03:42 PM
                          • soopacrucial
                            by soopacrucial
                            Hi folks,
                            10-29-2024, 02:40 PM
