HP W2207 What are the right caps?
  • tombodude
    • Feb 2012
    • 52
    Re: HP W2207 What are the right caps?
    Like the Samsungs, these come with either the highly adjustable stand, and also the small static one, I believe. Anyway I've seen it before. The actual stand is what has the pivot. I have no idea how the monitor knows it's pivoted, but it seems to.
    • hapollo
      • 15
      For future reference for those with this issue since this seems to be a common failing HP monitor, I can confirm the OEM temp ratings are 125C.
      Got one that had a white screen issue, replaced all the 1000uf caps with Nichons and the 680uf. Still white screen. Believe it to be a failed VR at U113 based on other threads here.
        White screen can mean the T-CON is not getting the b+ to the T-CON or the T-CON has blown fuse or failed T-CON.
        http://s807.photobucket.com/user/bud...ml?sort=3&o=20
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
