LG W2234S annoying popup
  • iKoopa
    • Mar 2013
    • Italy
    Hello buddies!
    I'm really annoyed for this troubleshooting:
    I've a LG W2234S Monitor that show the popup "OSD LOCKED / OSD UNLOCKED" continuosly and that hurts me becouse it doesn't desappear clicking the monitor's button.
    Could you help me to solve it?
    Thanks!
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: LG W2234S annoying popup
    Try holding the "menu" button in for a count of 5.
    If that doesnt work look for a factory reset
    Here is the manual
    https://docs.google.com/viewer?a=v&q...3nb2tScg_BGumQ
    • smason
      • 1652
      Originally posted by iKoopa
      Hello buddies!
      Thanks!
      I recently had an HP monitor doing the same thing.
      Recapped it re-assembled and it still did it.
      It didn't do it out of the case. I checked the switches and circuitry on the button board and found no problem. Re-assembled it and it was fine. I suspect it was a mechanical problem with the menu button that got resolved by repeated dis-assembly.
      • iKoopa
        • Mar 2013
        • Italy
        I tried to press the button but che pop up still to show.
        Is it possible tha is a cable problem? I relized that the energy cable is not the original.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Do the other buttons work
          Does the menu button switch the menu on and off
          • iKoopa
            • Mar 2013
            • Italy
            No.
            After released the held button the popup comes out again.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              May be a problem with the button board /cable/connector.
              • iKoopa
                • Mar 2013
                • Italy
                I've changed the cable but the problem persist...
                • giovengi
                  • Apr 2013
                  • 5
                  • Italy
                  may be not the same thing but for my benq i removed the button for "auto adjusting" popup
                  Unconfigured Ad
                  • Cerberuska
                    Mobo MSI B550-A PRO password popup
                    by Cerberuska
                    Hello guys,
                    I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                    BIOS I updated to last one.
                    any suggestions?
                    And same thing for two different 5600G, and yes, MoBo supposed to support it.
                    Thank you...
                    11-10-2024, 01:23 PM
                  • ivtec
                    How to get rid of this annoying win 10 notification
                    by ivtec
                    How guys ,how do i get rid of this notification, already had my win 10 self upgrade to win pro i guess by clicking on continue,now i have to click on remind me in 3 days. thanks...
                    09-05-2023, 04:55 AM
                  • Luis8
                    Samsung UE40F6400AY relay sound and reboots continuosly
                    by Luis8
                    Hi guys,
                    I friend of mine bring to me this TV because it started to reboot continuosly.
                    Sometime when the TV is really cold it startup correctly but when we shut it down and try to turn it on again it is stucked in bootloop.
                    When the TV fails to start i can hear the sound of a relay triggered in the PSU.
                    I tried to do some measurement and voltages are present in the connector to the mainboard but being the power supply intermittent i don't know if i can trust these measurement.
                    By the way if i disconnect the PSU from the mainboard the...
                    02-22-2021, 04:38 PM
                  • sauce
                    HP 13-ae019nf bios
                    by sauce
                    I need a clean bios because mine is corrupted (very strange things happen 3v3 enable S5_ON pulsing)
                    I tried a bios from this forum and it works but I would like to have my real serial number. And I made a mistake with DMI now have have a popup to confirm manufacturer mode and something like that but if I click yes or no the pc reboots and I have the popup again and so on...
                    And when PC power on it's very long and after few minutes I have "bios recovery files not found each time" and then the popup above
                    Here is my bios and my info :
                    08-21-2024, 04:18 AM
                  • flat-earther
                    Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                    by flat-earther
                    I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                    To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                    I have opened the camera and I think there is enough room to add something inside to accomplish this:
                    The camera is powered by a 3.7V nominal single cell lithium ion battery.
                    So I need to connect another battery in...
                    06-08-2025, 02:00 AM
                  Unconfigured Ad
